attila
Try this one....
FSTJACK said:Wing pic.
These pics do not show the adjustable wing supports or chute mounts that were fabed up after these pics were taken.
rottenronnie said:Chrysler claims a downforce of 400 pounds with the SRT10 wing at high speeds.
Something is causing rub marks way ABOVE the rear tires on my plastic wheel well liners without ever having anything in the box. I weigh 200 pounds and bouncing on the trailer hitch with the truck parked doesn't come close to lowering the box enough to get near those marks.
Also, that 2" wide slot underneath the wing is supposed to create what Chrysler calls a " horizontal cylindrical tornado" which creates a high pressure area on the tailgate instead of the normal drag.
So, I think the wing does "something".
Prof said:If you have ever experienced wheel bounce...that could be the cause.
I had that a few times before the caltracs.
rottenronnie said:I am on the 2nd set already.
They actually rub right through, especially after a long, fast trip. The dealer was quite confused and replaced them on warranty.
belgiumbarry said:what do you mean ?:dontknow:
rottenronnie said:The tires rub on the plastic wheel well liners until they rub through (split). But the areas where they rub through are ABOVE the tires (when the vehicle is stopped)
So something is dropping the box enough for the tires to steadily contact the liners; long enough to rub right through...the wing??
But I am talking sustained speeds of over 100.
The tires don't seem to rub at more normal speeds.
belgiumbarry said:are you lowered in the rear ? and what with stops ? are they still there, maybe half cut away ?
