WIP: Merc '49
Discussion in 'Other Vehicles' started by Floor, Jun 11, 2011.
  1. Floor
    Floor Full Access Member
    2,140
    Jan 16, 2007
    Belgium Antwerp
    up and up... the sky is the limit.
  2. rare03srt10
    rare03srt10 Full Access Member
    2,941
    Feb 3, 2011
    Fountain Valley, CA
    Just get EVERY bit of wiring from that totalled truck. Including interior/dash wiring. Shouldn't take to much fab to get the motor bolted in. Bolts in like a v8 just a little longer but hopfully it sits forward enough to leave the firewall alone. Have custom motor mounts made and As far as the slip yoke shaft goes just buy a regular cab alumium driveshaft and have it cut and welded to work with your car bro. Shouldnt be very hard at all. Heard of a few people doing swaps like this in other cars/truck and coming soon(maybe, probley, hopfully) a sandrail.
  3. belgiumbarry
    belgiumbarry Full Access Member
    5,209
    Feb 13, 2007
    Maldegem-Belgium
    hehehe, our FLOOR getting crazy :D now, succes with the project young boy... just don't forget "how" you want it on the road..... tuning "oldtimers" is now also forbitten in our banana land ... so you have only 1 option without "cheating" : get the car on O-plates before any changes . Afterwards you "can" change what you want but remember making it in fact impossible to sell ever , which requires a new tech inspection....:(
    but i imagine that crossed your mind already....
    good luck with the wrenching :rock:
  4. Floor
    2,140
    Jan 16, 2007
    Belgium Antwerp
    hey Barry, long time no see. How R doing? :p
    Yeah, did some research beforehand obviously... we're getting the sled ready for licence plate with (vintage) V8 & trans, then (only then) the real fun starts.... complete frame off, I only want to do this once :D
    Most likely the firewall will need some mod's, don't think the ten will fit otherwise. I was just wondering now how I can get the PCM (any OEM type) to work. If it is VIN independant it should be a no brainer right?
    You guys know which sensors (appart from those ON the engine) I need to connect/use without a complete re-program of the computor?
  5. ARRESTmeRed04
    ARRESTmeRed04 New Member Supporting Member
    5,880
    Nov 5, 2007
    central texas
    Even if the oem computer needs a vin number you can just use the one from your truck
  6. Flip
    Flip Full Access Member
    70
    May 6, 2010
    Atlanta, Ga
    Wow, thatz gangsta
  7. Floor
    2,140
    Jan 16, 2007
    Belgium Antwerp
    well thank you sir....:D
  8. Floor
    2,140
    Jan 16, 2007
    Belgium Antwerp
    got my hands on some desoto teeth and NOS bumpers.
    Picked up the engine from the forwarder last week... Now wondering if I need a stock wire harness or "viper harness for non viper applications".:dontknow:
    Salvage yard yanked out (= cut) some of the wiring that came on the engine
    Engine/trans is out of a 2006 Ram, ECU I got is from 2005 model.
    I'm planning to use autometer gauges.
    Guide me viper wizards ! :rock:
  9. ZCx
    ZCx Active Member Supporting Member
    9,786
    5
    Sep 13, 2007
    Big D
    first thing is if ya go with an '06 factory harness, will it plug into the '05 ECM???
  10. Floor
    2,140
    Jan 16, 2007
    Belgium Antwerp
    it should fit. PCM is good for all models.
  11. ZCx
    9,786
    5
    Sep 13, 2007
    Big D
    good deal:rock::rock:
    rare03srt10 is the member who has a buddy that might be able to help ya:rock:
  12. BADBLACKSRT10
    BADBLACKSRT10 Full Access Member
    459
    Feb 5, 2012
    Indianapolis, IN
    One of my customers has a '49 Merc similar to that one. What a heavy machine. Has a big block in it. Great car....good luck with it!
  13. Floor
    2,140
    Jan 16, 2007
    Belgium Antwerp
  14. Slitherbeast
    Slitherbeast Active Member Supporting Member
    2,278
    23
    Sep 10, 2007
    Alberta
    The best way is to find a "complete" wiring harness from a wrecked 06. It will be easier to elliminate the wires you don't need than to figure out the ones you do need. even the fuel system will need to be utilized. I have the 2005 service manual It is 175 MB . I will try to find a link.
  15. Slitherbeast
    2,278
    23
    Sep 10, 2007
    Alberta
    I PM'd you the linkfor the 06 manual. i downloaded it and it works !!
  16. 505'sFastestViper.
    505'sFastestViper. Full Access Member
    13,813
    Apr 26, 2007
    Farmington, N.M.
    there is a company that makes harnesses just for this my buddy just did a 20s doge and put a viper motor in it plug and play let me dig them up hold on
  17. 505'sFastestViper.
    13,813
    Apr 26, 2007
    Farmington, N.M.
  18. Floor
    2,140
    Jan 16, 2007
    Belgium Antwerp
    thks guys... very usefull.
    :rock:
  19. Floor
    2,140
    Jan 16, 2007
    Belgium Antwerp
    What is THE diameter of our rear axle? Plan to remove THE leaf springs and go for coil over shocks. What would you recommend ? 3 link or 4 link set up?
  20. Floor
    2,140
    Jan 16, 2007
    Belgium Antwerp
