FLSRT8 said:What will happen if you installed the wrong crank in the engine. A six speed with an automatic crank?
Stinker said:Dragon is the 04 not different from the 05-06?
the crank pickup on them?
WHEEWW! had me skeeered for a momentdragon said:your correct the 2004 is diffrent then the 05/06.
ummm what did it come out of...a SB chevy??? ...that could be bad...i think you're missin four lobes..two intakes, and two exhaust..!!!FLSRT8 said:What will happen if you installed the wrong crank in the engine. A six speed with an automatic crank?
Crank not camviperhauler said:ummm what did it come out of...a SB chevy??? ...that could be bad...i think you're missin four lobes..two intakes, and two exhaust..!!!
:congrats: :congrats: :congrats: :congrats: :congrats: :congrats:GADodgetech said:Crank not cam![]()
:marchmellow:
that's what i get for tryin to be a smart assGADodgetech said:Crank not cam![]()
:marchmellow:
And completely evaporate the entire blinker fluid system!BigRed460 said:That would instantly burn up the muffler bearings, there by causing major flux capacitor damage.
