Is that Sergio's truck again?
Carbon buildup on the piston top? How many miles? You might have to shim them so they get more clearance.
Sir, I would say your friend is experiencing detonation. I have had this happen in the past, and this was the cause.
Hope this helps...
Im gonna order the shims on line. We couldn't find them locally
weak rod bolts stretching, allowing the piston to travel to far at high rpm, next step is kablooey
The Rod bolts in these engines are not weak. No rumors need to get started.
There's no way I'd take 91,000 Mile motor to wide open. Not unless I was looking for a reason to tear inside it.
