The "after" explosion of unburned fuel in the exhaust. The backfire. Happens at that spot i guess. Also the hottest portion of the flame front being spit out by the engine is the very tip of it. By putting a cross over at that spot, it allow the fumes to evacuate down both pipes greatly reducing all the **** talk and popping. Top end power for x pipe, low end torque for H. The x pipe effectivly cross overs the exhaust throughout the rpm. The H pipe kinda dissappears as the rpm increases and subsequent pressure increases. The exhaust flow goes straight through its pipe and it really doesnt do much but equalize pressure.
Only thing is. This is much more effective on V-8's because they fire left, right, left right. The Viper fires both banks at the same time. Essentially a dual in line 5 cylinder. As a result you dont get the vacuum behind the pulse of exhaust gases to scavenge the exhaust from the opposite pipe.
Headers with the 2 into 3 setup for each side, helps pull some of the exhaust out the next cylinder from the same bank, but due to the nature of the dual firing 5's crossovers dont do a whole lot for power on these engines.
The Magnaflow Dual in Dual out muffler has a true x. Which means both inlets merge into one single 2.5 or 3 inch area, crosses over each other exits out opposite sides of the outlet. This would work great on a V-8 as you would only have one pipe at a time pressurized from that exhaust stroke.
However when you have both pipes trying to evacuate exhaust gases through the converged x pipe, in the magnaflow muffler, i think it causes congestion and un-needed backpressure. X pipe before the muffler would make no difference, just exacerbate the issue.
BIG FAIL :hmmmm2:
Was looking up exhaust options and came across this. Seriously, Really.. Uhmmmm........Why is there a firing order for these engines that does go left right left right. I think I've even seen it posted here before. Or am I missing something. Can someone shed some light...
