Is it ok to mix dot 3 and 4 brake fluid? This is for my clutch master cylinder resi only, NOT the brakes.
Yes, DOT 3 and DOT 4 are compatible. DOT 5 is the only one that will not work with the other 2.
Thank you. I couldn't recall where I read about it at.
a buddy of mine put dot 5 in is front master cylinder on his Harley and the front brake locked up while doing about 60 on a highway.. He went sailing.. Somehow he was ok.. The bike however didn't fare so well.
Do I need the limited slip additive in this axle.. Kinda getting confused, I have heard both ways now. But census says 75-140.
I run it in mine. This is directly from the Chrysler website:
DESCRIPTION - AXLE SRT-10
NOTE: DaimlerChrysler recommends using Mopar® lubricants or lubricants of equal quality.
REAR AXLE
248RBI - Mopar® SAE 90W
NOTE: Trac-Lok® differential requires Limited Slip Additive in the lubricant.
do you run the 75w-140 ?? or the 90W?
What's interesting is I contacted the local quick lube and they looked it up and their books stated it called for 75W-140
