shade
CarDude said:Thanks guys I am using all the ammo I have...
Here is my response to Canton....
Canton Racing Products Management,
Now that I have calmed down I will address your email in a more professional manner.
1. Your warranty is not a document for you to hide behind. Your product failed and cost me my engine, plain and simple. Ford Motor company's limited warranty didn't protect them from legal action when their product failed and cost people there lives. Ford had to pay even when the tires were purchased from Firestone. Just like in this case, you failed to act when you knew there was a problem. As Farmington has informed me, this is not the first failure; it (failure) has happened "quite a few times", to quote an engineer at Farmington. I don't care who sold you the parts...I purchased the final product from you.
2. You are correct the SRT10 engine has a normal range of around 70 psi, although it has spikes to 300 psi. The pressure bypass you referred to, is actually around 100 psi and it is a mechanical spring (so the precision is not there). The valve that you have chosen to use has a maximum psi range of 88.2 psi per its manufacturer's specs. Your negligent part selection is to blame here. You should immediately recall the part as it is in danger of costing you more than my engine. I am sure a class action law suit wouldn't be out of the question here. If you question my facts call Arrow Racing and ask for Todd (1-800-551-8477). They are the warranty rebuilder for all Viper motors. They dyno the engines before they return them for reinstallation into Vipers and SRT10 Rams. And finally the check engine light did go off, unfortunately the motor had already imploded. "A day late and a dollar short" as they say.
3. The vendor is not responsible as your pressure valve selection is to blame here.
I still fail to see why it took you six weeks to try and hiding behind your "limited warranty". If that is what you intended the entire time, you should have stated that up front, and not wasted my time. Your actions speak louder than words here, you know you are responsible. I hope you sleep well a night, knowing your are being dishonest. This is no way to run a business, except maybe into the ground. I did nothing wrong, except trust your reputation and install your system, which you designed for my application. If you continue down this road you will only be left with your parts, not your reputation.
I want the parts returned to me in the condition they were sent to you. I also want the results of the "test" that was run against the failed valve. I believe I paid for that test in full with my engine and my time you continue to waste. I want the full payment of my engine rebuild and all costs incurred due to your negligent inaction.
If you decide to go after it legally make sure you get what the engineers says in writing or at least write down their name and date you spoke to them and about what.
I would also record my calls regarding that stuff.
Good luck and yes they should stand behind it 100%.
