The ROE page.
First im using the srt4 2bar map sensor.
Second: If using a vec3 map goes above the blower
If using a sct map gets attached to the vacuum port at the passenger rear of the intake. I have a vacuum tee there and my boost gauge also goes to it.
Why not install the MAP sensor in place of the factory map sensor? It bolts right in place. I just took out the factory map sensor and installed the SRT4 sensor in it's place.
The Paxton is boosting into the OEM intake where the MAP senor mounts. The Roe has it's own intake. In order for the MAP to sense boost it has to be below the supercharger for the Roe (SCT only).
Damn!!! completely forgot that you ROE guys dont use the factory intake manifold
I need a favor for those who are still driving there trucks can you take a temperature reading of how hot the roe gets after driving it hard for a few hours.
Thanks
almost time to get back to work on this thing - after i get back from vacation - i should be heading down to tonys in a few weeks to pick up the rest of the past i need and finish this thing up for PCB 2011 woohoo
Let me know ill come down and give you a hand .
i got all the part i need - only 1 left , ill pick it up on sat and then time to get to work
if there a mod that can make this thread a sticky that would be great
thanks
Chris
PS
thank you tony !!!!
here alittle update....
unfortunately i sold the 540ci " for personal reason's " i would have sold the whole truck if i had too, but between the motor and selling my car it was enoff
i am back to a stock engine - and yes i do have the Roe installed, i talked with Torrie and Tony about the new setup
1. torrie wrote me a nice "safe" tune... thanks again buddy
2. Tony will be building me a new motor as soon as i get the funds - right now i have other importaint things to take care of.
so far the mod list will stay the same. w/o a 540 i was sad to see it go - but for tho who know why its well worth it...
its a minor set back.......
got the truck finish a few mth's ago
here are a few pictures of my setup - i dont have any current pictures ATM
the truck will be going to JTSVP for additional upgrades shortly....
