How Much Horse Power???
Dom426
Farmington, N.M.
can you make in a truck Naturally aspirated ???
at the wheel??
And redline???
with race fuel???
and still drive it on pump???
High 600's with pump gas is doable. :rock::rock:
A HP cam will get you there, but you will loose torque.:mad:
Yeah I say high 600's too. High compression, tall duration/lift roller cam should get you there.
Full billet block and all out build a little over 800 rwhp There is a build in Toronto running that now. It's a big bux build.
we looked into it...but a stock block is good for over 3000k hp and close to 9k rpms
I don't think that was the reason "to much hp" I think they were going for a massive cc / ci for u americans increase and stroked set up. Apparently the goal was 1000hp but I have not spoke to him in ages to see where they are or what happened. Las it was at 800 and change at the rw.
Ok makes sense. Thanks for the info ken
