Power Steering Pump
Discussion in 'Wanted' started by SHU-DOG, Mar 12, 2013.
  1. SHU-DOG
    SHU-DOG Full Access Member
    816
    May 18, 2006
    Just Moved to Reno NV from Southrn Calfornia
    Need a new power steering pump.
    Ive already done Tonys braided lines.
    Pump is spewing almost all the oil outtah it just when i warm up the engine.....cannot drive it.
    Stealership wants BIG $$$$.
    Thanks
    SHU
  2. VENOMOUS1 RACING
    12,751
    2
    May 15, 2009
    Wacko Waco,TX
    Spewing from pump itself or lines bro? Hadn't seen a pump itself leak? I'm sure they can though. :dontknow:
  3. phxpoolguy
    phxpoolguy Full Access Member
    3,747
    May 6, 2009
    phoenix
    Got mine from CARQUEST for like $60-70, haven't had any problems. You'll have to swap out the pulley and reservoir though.
  4. SHU-DOG
    816
    May 18, 2006
    Any chance you have a part #?
    Everything i pull up is like $500 for the pulley, resevoir, pump n bracket.
    I was hopeing to swap out the old one and install the new one?
  5. TheMoparConnection
    TheMoparConnection Full Access Member
    3,978
    2
    Jun 9, 2006
    got 2 dodge options for you... you dont have to replace the bracket and all that. thats for the other 1500's not srt-10
    brand new pump p/n 5093985AA list for 355.00
    reman pump p/n R5093985AA list for $139.00
  6. FlyingLow
    FlyingLow Active Member Supporting Member
    4,903
    May 27, 2006
    Chesapeake, Va
    Mine dropped all the fluid last night. Just had it towed to the dealership this morning. Still waiting to hear what is wrong.
  7. Theol55
    Theol55 VTCoA Board
    2,045
    Sep 15, 2011
    State of Confusion
    That Blows!
  8. phxpoolguy
    3,747
    May 6, 2009
    phoenix
    Part number is 20-608, $87.99 with core. Reservoir is only held on with two clips, pulley is easy to swap but you can probably have a shop take it off for $25 would be my guess. Only three bolts hold pump to engine, pretty easy job really.
  9. SHU-DOG
    816
    May 18, 2006
    I think this is for a Viper car not the truck?
    Is there a difference?
  10. SHU-DOG
    816
    May 18, 2006
    And this pump swapped in no issues?
    Everything mounted right back up?
  11. TheMoparConnection
    3,978
    2
    Jun 9, 2006
    no this is for the truck.
  12. phxpoolguy
    3,747
    May 6, 2009
    phoenix
    Same exact pump, no problems at all.
  13. ViperCLKGTR
    ViperCLKGTR Active Member
    1,092
    9
    Jun 3, 2012
    When I did mine back in November, I had the same exact problem. I had leaky lines that I ended up going through a bottle of fluid every week. Got the new lines on and as soon as I turned it on and turned the wheel to see everything was good it started spewing from all over the pump. Only thing I could think was the pump was getting warn out and exhausted from being run low and sadly empty a few times that when it went back to regular pressure it couldn't take it.
    Tony said to go OEM but I just couldn't see(or afford with the holidays) spending $250+ on a P/S pump. I went to O'Reilys and they ordered me a remaned one with a lifetime warranty. I said if this one went I would go OEM but it's been 5 months now and not a issue yet.
  14. phxpoolguy
    3,747
    May 6, 2009
    phoenix
    I have bypass lines since I no longer have hydraulic fan, so my PS pump is really working good with what I'm running.
