10 Quickest SRT10's
Like i told you on the phone, get a WOT box. It's less than $200. If my trans wasnt grenaded id go make a video to showcase how easy it goes into gear.
That goes for the rest of you who like to power shift. Get a WOT box. It will help you be more consistent.
Iv always been curious about this but I dont know how it would work with my nitrous
I'm going to get one after I'm done racing this year have a list that's just getting bigger
1. Nano-nitrous pusher
2. Lift the front end .5" and lower the rear 1.25"(hoping to shift the center of gravity up a little to see if it'll help with weight transfer)
3. WOT box
4. More weight reduction somewhere
5. Rebuild the trans if money is ther
You have adjustable shocks yet in all 4 corners? That and drag springs in the front is my goal. Unsure what is out there for 10's. Athough if you cutting 1.5's, that's good enough for the power level unless you spraying off the line. But i dont see spraying off the line being consistent.
6. QA1 shocks....
Spraying a 100 shot off the line 60's are between 1.51 and 1.59
He was running 11.50's before. Perhaps it gets exponentially harder to cut times, the faster one goes?
It does, but a 200 shot should shave his times more than 7/10's. His fuel jetting is way different than mine, Justin says his is running pig rich.
6. QA1 shocks....
That's good to hear.
On another note(sry for off topic), it may be a good time to start saving for an engine rebuild just in case. I hate to be negative but i been there. It really sucks when a motor goes and the truck has to sit for a long long time to save and fix it.
If/when the motor goes ill just go park the truck in a field somewhere
Current List:
1. Dom (505'sFastestViper) - 9.09 @ 147
2. J. Young (unregistered) - 9.71 @ 141
3. Mike (nowwhat) - 10.73 @ 125.1
4. Craig (srt10x3) - 10.88 @ 127.12
5. Justin (ARRESTmeRed04) - 11.04 @ 122
6. Tony (JTS VENOM PERFORMANCE) - 11.21 @ 126.74
7. Justin (JMB Justin) - 11.30 @ 119.7
8. Ken (SRT10VENOMOUS) 11.51 @ 121
9. Rick (phxpoolguy) - 11.56 @ 118
10. Jerry (Trainman) - 11.63 @ 117.9
Rick you and Jerry need to get your buts to the strip. Ya'll are 9 & 10. Too close for comfort. As soon as I get mine finished, 5 or 6 years, I will be bumping you two down.
Can yall add basic mods to the list like power adder if any and trans type. Would be nice to see single cabs, QC's, autos and sticks.
No, Sir. Each combination is unique. Generalizing them based on a couple characteristics isn't sensible. As it sits right now, no two trucks on the list run the same combination of weight reduction, power adder, trans, and suspension.
I think we should start a list of NA trucks. Because all but Jerry's have some sort of helper installed. :dontknow:
