VENOMOUS1 RACING
received mine and they look awesome cant wait to get them installed. Scott powder coated them to match my truck for me![]()
They're gonna look awesome on that truck too:drool:
Nice to see more getting out there without all the negative interference..........
Dom do mean he can actually change what our post say? Can anyone do this?
I need me some traction bars:/
How long are these things.... They look double the caltracs! Considering picking them up tax time!
Depends if you have a Rc or Qc.
Not 100% sure on length because I have them for a Rc . It mounts under your rear end using your u bolts. You just simple remove the stock plate under your leaf and bolt up new one. Other mount goes on bottom of frame rail under your cab. Its where the 2 pieces of frame come together. It is u shaped so you just hold it mark your holes drill and mount then your bars will just onto both mounts
They're longer than Caltracs by a good bit as I designed these to not only locate rear end and prevent wheelhop, but to also transfer weight from the front end to the rear tires to firmly plant tires to the asphalt![]()
