ViperCLKGTR
- Joined
- Jun 3, 2012
- Messages
- 1,092
- Reaction score
- 9
How do they ride? 22's are pretty rough, couldn't imagine the 24's being that much worse ha
are they only availible in chrome finish and black ?
i would like to see them like the OEM factory's , polished i guess ??
How many people have just assumed it was a stockish truck and found out the hard way it isn't?
When going to the larger rim did you compensate for the gain with a smaller tire or is the speedo off?
Also where did you get that hitch cover!!!
What is the difference in length from the lug nut to the center of the V in the spoke? The 24" wheels look a lot longer of a distance if you get what I am asking.
The tire to rim size is less important than over all tire height or diameter. Bigger than stock = you will be moving faster than the speedometer needle shows. Smaller than stock size will be opposite. The odometer will also be off.
The bigger wheels will not effect the speedo accuracy.
