2006 bone stock dyno.
Discussion in 'Dyno Stuff' started by uberpube, May 3, 2015.
  1. uberpube
    uberpube Full Access Member
    39
    Feb 21, 2015
    Black Diamond Alberta
    Just did a couple of pulls today. First pull, the tires slipped on the roller. I had to crank it down pretty hard. I am thinking the stock exhaust/cats are pretty restrictive.
  2. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    There were a few 2006 trucks that had retarded cam timing from the factory, those numbers are very low!
  3. mopar-or-no-car
    mopar-or-no-car Full Access Member
    3,086
    Sep 18, 2012
    North West Ohio
    torque is just about there??? Right?
  4. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    Negative, that's low as well. Should be around 440-460.
  5. topfueljim
    topfueljim Full Access Member
    138
    6
    Oct 2, 2014
    SoCal
    Maybe I'm missing something, but why does the sheet say 1978 Dodge 440?
  6. BigRed460
    BigRed460 Full Access Member
    3,052
    17
    Jan 2, 2007
    Texas
    Peak power at 4k rpm? dafaq?
  7. uberpube
    39
    Feb 21, 2015
    I forgot to change the file directory from when I had my ramcharger on. It dynod a continent shifting 132 rwhp btw.
  8. oldcolt
    oldcolt Striker Heads and Cam Supporting Member
    2,771
    161
    Jul 14, 2008
    Calgary, AB
  9. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    [ame]http://www.youtube.com/watch?v=ZuGGahzfgTA&feature=relmfu[/ame]
  10. uberpube
    39
    Feb 21, 2015
    Thats interesting. Did you guys happen to take cranking compression numbers before and after?
    It would be interesting to see what your truck reads on my dyno, it has made lower readouts than some other Calgary area dyno's on other cars.
  11. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    I'm sure Ronnie has it in his notes somewhere. Whose dyno are you using?
  12. uberpube
    39
    Feb 21, 2015
    I think an exhaust change is warranted on this thing as well...This truck is way to quiet for a 8.3 litre V-10. On the dyno this truck had no exhaust noise whatsoever. The only noise was the tires on the rollers, the 05 I test drove in Edmonton had a lot more raspiness to it.
  13. uberpube
    39
    Feb 21, 2015
    If you have the numbers I see what they are on this truck, probably a good baseline to do anyway.
    I have a dynojet 224xlc in my garage.
  14. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    You are my new BFF!!
  15. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    You will pick up a little bit of power with an exhaust mod, but you are better off spending some money with Torrie and try to wake that truck up. If it doesn't respond, you may have the same cam issue that I did.
  16. uberpube
    39
    Feb 21, 2015
    Its stuff like this is why I have the dyno, I have a fleet of modded junk and performance oriented models, and I like to play with them.
    I'll probably order a complete system up and test it again just to rule it out. My friend that works at a dodge dealer said that he's seen a few mufflers piling the baffling up and choking the engine on srt10's .
    Its got 40k on it on original plugs and wires, I am ordering the Davis Ignition kit for it. I should have pulled the air filter on the dyno, its not exactly fresh.
    I got new tires coming for it as well. This truck sat a lot,the BFG KDWS are completely dry rotted, just ordered a set of toyo proxes stII's . If anyone in Alberta needs rubber, they are way cheap at 4wheelparts.com with free shipping to their store.
  17. stealth78
    stealth78 Full Access Member
    2,611
    18
    Feb 15, 2012
    MA
    Houston we have a problem :joyman:
  18. uberpube
    39
    Feb 21, 2015
    it's a bit of a chore to dyno the truck, it doesn't strap down well and it moves around a lot more on the roller than even higher hp cars that have been on the roller. Next time I am going to strap the axle as well.
  19. caveman
    caveman Well-Known Member Supporting Member
    7,508
    36
    Jul 20, 2011
    Western Colorado
    Can you please ad your location to your profile? Thanks.
    I'm not sure if I should ban you for this or make you a moderator? :D
  20. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
