2006 bone stock dyno.
Discussion in 'Dyno Stuff' started by uberpube, May 3, 2015.
  1. NukeGM/Ford
    NukeGM/Ford Active Member
    1,804
    11
    Oct 4, 2014
    North Las Vegas, NV
    i thought 20-25% lower than advertised was normal when done at the wheel for driveline loss??
  2. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    15% for manual trans cars, 20% for slushboxes.
  3. stealth78
    stealth78 Full Access Member
    2,611
    18
    Feb 15, 2012
    MA
    Sorry for the confusion... I thought the pic of your Dyno run was going to be "quoted". My smart ass remark was targeted at your HP/TQ #'s. I was not implying that there was an inability to strap down the truck. Good luck regrdless, it does seem that you may be one of the "lucky ones" that has a retarded cam issue, rare but it has happened.
  4. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
  5. flamesarewicked
    flamesarewicked Full Access Member
    190
    Apr 9, 2014
    Saint Landry, Louisiana
    mine dynoed a little more than I expected a mostly stock one would. granted a dyno is a tuning tool and dynos vary.. mine put down 445rwhp. the previous owner had it done at Futral Motorsports in Walker, La. they mainly work on GM products so maybe that's why it pulled such a good number lmao. the owner before him brought it to the track and had a best of 12.88@105mph so.. it's a peppy ride for sure.
  6. uberpube
    uberpube Full Access Member
    39
    Feb 21, 2015
    Black Diamond Alberta
    That's what I would expect a viper engine to do at the wheels, a 48 re will eat more power but not 90 or so more, so I do believe there is something wrong with mine.
    Off topic dyno post warning .:eek:
    Numbers do vary between different manufacturers , but if you dyno'd on a dynojet and have an sae corrected number, the numbers will be comparable. The good thing about dynojets are they all calibrated to the same standard so they all read very close. I use to have a dynojet 248c before I bought the dynojet 224, the cars I ran on the 248 made the exact same number on the 224xlc, I made a point of testing my super repeatable n/a rx7 on both to test the consistency as advertised by dynojet.
    When I was shopping before I purchased the 224, I asked all the different manufactures for customer referrals, dynojet came up with a ton. I phoned a dozen or so, a lot of them were racers that travelled around and needed a machine that was consistent with other machines in other places. That's dynojets strongest point, by not offering open software with correction factors, and using fixed inertia's for measurement, they can have consistency. Its like selling tape measures, if you sold ones that are elastic or with moveable markings, how well would that work for uniformity of construction? The beauty of the xlc is it also has load bearing that can be turned off and on for tuning purposes, although the 248c also had load bearing via proportional air braking, so its not really true when people say the that earlier dynojets are inertia only. I load cell tuned a lot of cars with the 248 on the air brakes and it worked fine, it just didn't have real time torque readout like the 224 xlc, and the 248 was a giant machine that took up way to much space compared to the 224 xlc.
  7. SRT10ROD
    SRT10ROD New Member
    11
    May 8, 2015
    Did this only ever effect the Viper Trucks in 06' or the cars also?
  8. VPRPWRD
    10,836
    10
    Mar 28, 2012
    PA
    I've only heard of it in the trucks, not sure on the cars.
  9. uberpube
    39
    Feb 21, 2015
    Spent some money on the truck yesterday:
    First round:
    Magnaflow catback
    K&N intake
    Magnecore 8.5 wire set
    NGK plugs
    Stoptech cross drilled rotors
    Green pads
    That stuff should be here in about 2 weeks.
    Next on the list :
    Belanger headers and mids
    SCT pro racer software
    SCT x4 flash programmer
    I'll see where the power is after this, if its still low, I'll degree the cam.
  10. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    I'm going to be selling my MOPAR headers and mids soon, if you are interested.
    [​IMG]
    The Borla cat-back in the pic is already sold.
  11. uberpube
    39
    Feb 21, 2015
    Yup, interested, could save me some US currency conversion pain.. What are you changing to ? Twin turbo? :chain:
  12. guyrobert
    guyrobert Full Access Member
    454
    Jun 21, 2007
    Vancouver
    I have a MagnaFlow catback and a Volant CAI if you haven't bought the one in the US.
  13. uberpube
    39
    Feb 21, 2015
    They already dinged my card so probably to late.
  14. guyrobert
    454
    Jun 21, 2007
    Vancouver
    No problem, if they haven't shipped yet, you may be able to reverse the $$
    I would want $500.00 CDN + shipping for both.....
  15. uberpube
    39
    Feb 21, 2015
    MagnaFlow and k&n done. Noisier for sure but seat of the pants feels the same. I will dyno it when I have time, probably in a month or so.
  16. guyrobert
    454
    Jun 21, 2007
    Vancouver
    You will see a big difference with part 2 of your performance upgrades
    you might want to add a ported throttle body and an under drive pulley it's cheap hp for the $$
  17. Wombat
    Wombat New Member
    Aug 10, 2015
    Victoria BC
    hey do you still have the headers
  18. 10-1=9
    10-1=9 Full Access Member
    1,735
    4
    May 21, 2014
    Allentown Pa.
    Them lawn ornaments are better than a garden gnome
  19. oldcolt
    2,771
    161
    Jul 14, 2008
    Calgary, AB
    Sorry they sold last month.
  20. LeadFt
    LeadFt Full Access Member
    67
    May 23, 2012
    Seems pretty low
