Slave Cylinder Help
Who/What is JMB? any links?
JMB Justin .. use to be a vendor on here ,, may still be .. I haven’t been on in a long time .. Justin is the guy that did the build on the fastest viper truck for 505fastestviper ( Dom ) JMB is one of the first to make and fabricate mods for the trucks ..
his link : https://jmbperformance.com/
Roe Racing has the upgrade kit for $600 US. Supposed to come with complete instructions for installation - anyone use this before? Experience? Good/bad?
If the truck is stock, then just get the same composite slave. Like 100 bucks or so. Since you are dropping the transmission, thats the best time to put a new clutch in and get the flywheel resurfaced. Stock luk clutch is fine.
Update: I'm picking the truck up this morning. I bought the Roe Racing Kit and had it installed. I can't do that type of work anymore - the old elbows are too screwed up to do much wrenching anymore.
Any suggestions and/or pictures of where to mount the fluid reservoir? Right now its mounted with tie wraps and once I get it home i want to build a bracket to securely mount it off the firewall. It's secure but I don't like it and my mechanic is not a fabricator so I need to build a bracket.
After reading all this and so many posts like it, I am so glad I sold mine. I really enjoyed the truck. However, the looming costs and headaches of part replacements was something I was not interested in. Especially when it comes to parts that are no longer available. What a shame.
Good luck with your bracket.
Mine bolts to the firewall just behind the brake booster. '05 reg cab w/6spd. Yours should be the same.
