All door speakers stopped working
Discussion in 'General Discussion' started by VIPR PWR, Aug 4, 2019.
Car Parts
  1. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    all 4 door speaker have stopped working on my truck ,, infinity system .. anybody have the fix for this ?
    Found this on the web ... no idea what the heck this guy is saying ... and audio gurus out there ?
  2. ViperPete
    ViperPete Full Access Member
    2,659
    15
    Aug 4, 2010
    Ocala, FL
    Does the stock amp turn on?
    Do the dash speakers work?
  3. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Yes , all the rest works ,,, except sometimes it can take 10,15 minutes for the sound to start ,, other times it starts as soon as I turn the radio on ...
    I was getting a buzzing crackle noise from the speaker in the drivers door a few months ago .. now all the door speakers quit
  4. Matthew Bartels
    Matthew Bartels New Member
    6
    Apr 14, 2019
    So were you able to change out that relay? I too am now having this issue. and if so how easy was it to access. I was going to try and find this out so I can get that fixed.. might also see if this is covered by my extended warranty.
  5. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Haven’t had time to look at it yet .... to damn hot here besides ....
    Matthew Bartels likes this.
  6. Skypilot68
    Skypilot68 Full Access Member
    1,494
    98
    Apr 23, 2012
    Pacific NW
    Something in the air lately???..as my speakers suddenly have a mind of themselves...one day they work fine..but then later that day..nothin'. It's all still factory setup..fuses look ok...maybe it's my choice of music???
  7. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Might be the music ... is this what your listening to ;
    Matthew Bartels and Skypilot68 like this.
  8. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Another thing might be the wires are broken in the harness from the body to the door ... seems to be a common problem with the dodges
    TrailMix likes this.
  9. NukeGM/Ford
    NukeGM/Ford Active Member
    1,804
    11
    Oct 4, 2014
    North Las Vegas, NV
    Amp for the door/dash speakers is behind passenger air bag. Real bitch to get out
  10. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    That’s the kind of thing I am trying to avoid doing ... I want the simple fix lol
  11. Skypilot68
    1,494
    98
    Apr 23, 2012
    Pacific NW
    More of a George Thorogood & the Destroyers fan..maybe I should refine the bass.
  12. Matthew Bartels
    6
    Apr 14, 2019
    I asked around and some others are saying it is specifically the infinite system. so might need to do more than the relay. I hope not cause I do not want to take the dash out.
  13. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Curious if that would affect just the left door speaker at first ?
  14. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    I’m with you on that ... my next step will be checking for broken wires to the drivers door speaker , harness between the body and door ..
  15. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Does someone have a wiring diagram for the 2005 sound system ..
  16. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Yes ,l I found that out .. took the glove compartment door off to see it ... no freaking way it can be removed from there without ripping into the dash ... I saw 1 wire plug and everything looked fine ,,, I got my hand in far enough and could feel the amp and it was warm .. ... without being sure it’s the amp ,, I’m in no way tearing the dash apart and replacing it .. just to find out that isn’t the problem ... any idea if there is a easy way to bypass it without having to tear the dash out ?
  17. Bob
    Bob New Member
    4
    Oct 2, 2019
    MD
    Greeting, gents. New member, wanted to let you know that I had success with the dash amp by using a 1/4 inch wobble socket and removing the radio bezel. So basically Take the bezel off, it'll expose little angles for you to reach the backside of that amp and with the wobble socket, 30 minutes.
    VIPR PWR likes this.
  18. VIPR PWR
    7,608
    2,958
    Jun 12, 2007
    FL
    Thanks ,,, it may end up being a project in the near future ... I’m still not sure if it is the actual problem .. bit when I have more time I’ll be giving my diagnostic skills another try ..
    welcome aboard
    Bob likes this.
