MOPAR Stainless Headers
OldColt has the chrome valve cover stick-ons and they look great. Much cleaner than the brushed/corroded oem look. However, with a bit of work, that can be maintained to look decent. I know, I've been cleaning mine for 15 years. :)
A company called "Appliance" made white headers back in the early 70's that looked pretty cool. Unfortunately they were spray-bombed (not powder-coated), were made of mild steel (NOT stainless) and showed off the " grimy black-hand" installation markings.
They looked nice for a week or so until the paint burned off and rust spots started showing up on the bare steel. Ceramic coating is WAY tougher.
SLITHERBEAST: Ditto with the steering bolt whacking the #3 primary tube. A wee bit of grinding solved the issue. The twisted flange on #5 required a bolt extender to turn it into place (almost). It was not unexpected but disappointing what with laser-guided measuring systems, precision CNC machining and 3-D printed burgers :eek:
Which tube is #3? The second one back on L/H header, correct? Where is the bolt located?
1-3-5-7-9 (Driver's Side) front to back.
2-4-6-8-10 (Pass Side)
Bolt is located on the steering shaft coupler. The guys doing your headers can watch for that. IOW, when you turn the steering wheel, the bolt will hit the #3 header tube a little. Best to fix it before it wears off the ceramic coating.
Drivers side you say.....yeah...na I don't think my engine has been converted too lolo_O
All this whizzy sci-fi stuff these days: Laser alignment, precise and repeatable CNC machining, cool new alloys, SSD and USB thumb drives for computers, 3-D printed hamburgers (well, maybe not the last one in the list) and yet exhaust system manufacturers still can't build a header that just bolts up. WTF?!?
What is the chrome valve letter made of? Is it metal or some other type of material like plastic.
Thanks for the info. Do you know how much the cost is to have the headers coated, and who would you recommend?
Bill,
I would use Jet-Hot. Their business is heat management, corrosion, and friction reduction by using coatings. Their world headquarters is in Burlington, NC. They have a web site and can quote you online. Their # is 1-(800) 432-3379. They are a little more expensive, it cost me $320.00 back in 2010 to coat my headers. Their online link is: https://www.jet-hot.com/coatings.
I hope this help you.
A science Experiment:
Both Aluminum and Magnesium ignore magnets (Gen II and Gen III Valve Covers)
Magnesium reacts with Vinegar (Gen II Valve Covers)
Aluminum does not react to Vinegar (Gen III Valve Covers)
The end.
The end.
On that note....I think will carry on wheel barrowing bark mulch down the steps to the garden
IF you can ever get magnesium to catch fire, it is something to behold.
So tonight (is it night there now?), when you have finished gardening/bark-mulching, find some old Gen II valve covers and throw them on the Bar-Bee.
This should entertain yourselves, your neighbors and quite likely the fire department.
Nothing cleans years of Vegemite residue off your Bar-Bee like a good Magnesium fire!!
We are 6 hrs behind but tomorrow or 18 hrs ahead.
Eeeww! Vegemite on a bbq gross. Great on toast tho, very fine smear only as it is too concentrated
You are in quite a mischievous mood tonight. Sound positively dangerous
I use a bit of good old oven cleaner (caustic) on my BBQ that gets it clean, just hose it off.
Yes it is. We had an A-6 make a hard landing on the JFK, and for whatever reason, the left main mount wheel froze up, skidding down the deck. It then snapped off, and caught fire. Nothing says mesmerizing like a magnesium rim in full blaze. It literally started melting into the deck, until the deck crew were able to push it over the side of the ship. Interesting to say the least.
