JTSVP PS Lines Leaking?
Discussion in 'Performance Mods' started by misterak, Jul 2, 2015.
  1. Ivan Navarro
    Ivan Navarro New Member
    25
    Apr 21, 2012
    Lubbock, TX
    Sorry I'm opening this topic up again but I'm guessing you sale this stewing line or fitting needed for the hydraulic fan steering line?
  2. Ivan Navarro
    25
    Apr 21, 2012
    Lubbock, TX
    Sorry to open this thread up again but my ps fitting by fan just crapped out. You sale this fitting or a much better option before goby through dealer?
  3. viperhauler
    18,950
    44
    Jul 27, 2008
    don't buy the dealer one. they're shit.
    either have local lines made or order the ones from JTSVP.
  4. NukeGM/Ford
    NukeGM/Ford Active Member
    1,804
    11
    Oct 4, 2014
    North Las Vegas, NV
    yuuup
  5. Dave Bryan
    Dave Bryan New Member
    15
    Oct 27, 2021
    What kind of washer did you replace with? I am having this same leak issue at the fan with the stainless braided upgrade lines.
  6. Dave Bryan
    15
    Oct 27, 2021
    Hi- how did he make it right? Re: how did the upgraded braided lines work with washer & rubber oring/insert at fan without allowing leakage?
  7. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I think the overall design worked on some (most??) installations but relied on the aluminum casting being perfectly flat (and not too porous), to be leak free. It's a big ask for a rubber inserted metal washer to hold back that much pressure, reliably.
    Unless it was redesigned to use a fitting that went inside the casting with o-rings, like O.E.M., I think "make it right" would mean refund.
    If I had to guess.
    AMS3 likes this.
  8. Dave Bryan
    15
    Oct 27, 2021
    Ah ok- do you have a pic of lines you had made possibly ? Mine's stuck in shop leaking at fan connect.
  9. Dave Bryan
    15
    Oct 27, 2021
    I don't have a hose shop near - big ask here--- could I pay you to have some made like yours at your hose shop? I'll pay twice cost of hoses or whatever is fair to you for your time. I'd love to try them, especially if keep from any changes in steering pressure etc. I want to get these ps lines leak free.
  10. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I took the oem lines to an Industrial Hose shop. They re-used the OEM fittings on the new hoses with the exception of the problematic swivel in the hose coming off the top of the ps pump. The swivel was just simply left out. The hoses are rated at 3500 psi over (over twice the pressure the pump can produce). The steering works as it should with the same feel as OEM.
    I'd grab a set of leaky hoses which you should be able to get cheap. Send them to an Industrial Hose place and have them upgraded to 3500 psi (or so). Using silver solder, they are tough as nails and won't leak.
    AMS3 likes this.
  11. Dave Bryan
    15
    Oct 27, 2021
    My srt-10 is stuck in shop with leak at the fan. I don't have a hose shop near - big ask here--- could I pay you to have some made like yours at your hose shop? I'll pay twice cost of hoses or whatever is fair to you for your time. I'd love to try them, especially if keep from any changes in steering pressure etc. I want to get these ps lines leak free.
  12. rottenronnie
    4,178
    2,153
    Jul 4, 2006
    Calgary, Alberta
    I'm not able to help you at this time; not the least of which I'm up in Calgary, Canada.
    Honestly, any competent Industrial Hose Shop could help you out.
    All they need to do is eliminate the Swivel and use the factory ends on the new hoses.
    And you can do the same thing with the Oil-Cooler Lines.
    BIG difference in sealing 100 psi (Oil Lines) and trying to seal 1500 psi (Power Steering Lines).
  13. Dave Bryan
    15
    Oct 27, 2021
    Ok thanks appreciate.
  14. GSJake
    GSJake Active Member
    207
    106
    Feb 13, 2018
    I would just order these..
    https://shop.jtsvp.com/product.sc?productId=553
    Even though others have said they leak, improper torque at install can be a factor.
    Mine (knocking on wood) have been leak free for 3+ years.
  15. Dave Bryan
    15
    Oct 27, 2021
    GSJake likes this.
  16. GSJake
    207
    106
    Feb 13, 2018
  17. Dave Bryan
    15
    Oct 27, 2021
    Careful with the fittings regarding how tight get them or alignment or ?-----so I can tell mechanic.
  18. GSJake
    207
    106
    Feb 13, 2018
    Both. There is a sending and return line.. ensure they are correct and they are not over torqued.
    Are you taking it to a dealer or a independent?
  19. Dave Bryan
    15
    Oct 27, 2021
    Ah gotcha. Thanks. Actually truck is at a mechanic @ a Ford quicklane (not dealer). So I'll tell not to over torque them.
  20. GSJake
    207
    106
    Feb 13, 2018
    Interesting.. is that like an oil change place or?
