I’ve been using these since the factory dust squeakers .They have worked great . I’m About to put the new fronts I have on ..
https://www.zeckhausen.com/catalog/index.php?cPath=13_3576_405_14_209
I’ve been using these since the factory dust squeakers .Hahaha the good ole dusty skawwweeeeeekers .. those were extremely annoying till I replace themI still have the factory installed - go figure right lol
Dust is horriblle - and so ugly!Hahaha the good ole dusty skawwweeeeeekers .. those were extremely annoying till I replace them
Yes , and yes a I’ve heard that hahahaDust is horriblle - and so ugly!
Increases the risk of the wheels rusting tremendously![]()
Loudmouth lime!I just installed powerstop Z26 pads front and rear a couple weeks ago when recoating my calipers.
Looks good behind black wheelsLoudmouth lime!
Yah red and green could be to christmassy!Looks good behind black wheels
grinch greenLoudmouth lime!
What paint did you use and did you clear coat them ?I just installed powerstop Z26 pads front and rear a couple weeks ago when recoating my calipers.
G2, no clear, it is great stuff.What paint did you use and did you clear coat them ?
Thanks .. I was looking into the types people use ,, dupli color, VHT and G2 … did you use the brush on or spray on ? I was reading that clearcoats aren't needed and shouldn’t be done yet some seem to do it ! And was curious if any of these paints will hold up in the case the caliper lock up like they have done on many trucks , including mine . Mine got so hot the brakes were smoking and once at night the rotors glowed read .. scary shit ! Dodge should be forced to have a recall befor someone’s truck goes up in flames or crashes.G2, no clear, it is great stuff.
https://g2usa.com/products/g2-original-brake-caliper-paint-system™
I have used it on a bunch of cars, I usually do it twice (two years in a row) to get a great glossy coverage.
I love it more than powdercoat because you can always fix it if it gets damaged.
Buy it on Amazon
Brush on, it smooths out so nicely. Nothing after, no clear. But it must dry 100% before you put brake dust on it. So take a weekend.Thanks .. I was looking into the types people use ,, dupli color, VHT and G2 … did you use the brush on or spray on ? I was reading that clearcoats aren't needed and shouldn’t be done yet some seem to do it ! And was curious if any of these paints will hold up in the case the caliper lock up like they have done on many trucks , including mine . Mine got so hot the brakes were smoking and once at night the rotors glowed read .. scary shit ! Dodge should be forced to have a recall befor someone’s truck goes up in flames or crashes.
Cool , thanks again ! Wouldn’t want to dust up the new paint . Hand painting as long as the paint smooths out is what I was thinking was the better option even without removing the calipers . Just wasn’t sure about the actual results .Brush on, it smooths out so nicely. Nothing after, no clear. But it must dry 100% before you put brake dust on it. So take a weekend.
Geez! That's terrible! Hope it's just a normal bruiseBefore and after in the last 2 days were they did the incision in my thigh through the femoral artery to run some long finger to pick the large booger out of my brain (blood clot ) . Sure hope it’s not a internal bleeder at the incision now ..
