The Engine Build
.. scrap the chevy lyics lol
Still waiting on last parts shipment. Should be sent soon. Has clutch in there and I need that for balancing.
Engine builder has had shoulder surgery today. He is now out of action for a few weeks.
Just take a breath and relax, it is happening. Just not as fast as you would like. lol
Yep ,, just sit back and listen to Rasclal Flatts over and over again hahaha
Dang! I think I can feel a country music song coming on.
I'm sure I can write a song about that engine. Yeehaaa!
I might just goes down to the liquor store and gets me some ammo.
A 6 pack and shoot some varmints. C'mon Cletus, go on now, get in the truck
Now thats a plan ...getter done hahaha
Final parts crate has left Tampa FL Wahoo!!!!
Inside is
Go Fast Camshaft
Slow bleed lifters
7.600 hardened pushrods
Oil pump gear set
ARP Head studs
Lower end gasket set
Head Gaskets
Valve cover seals
TB O’ring
Clutch, pressure late, bearing, alignment tool
10 NGK spark plugs
Valve cover spacers
Timing chain
So the only original parts in my new engine is the crankshaft and......um
timing sprockets, repaired oil pick up, timing cover.
Not much.
Inside is
Go Fast Camshaft
Slow bleed lifters
Oil pump gear set
ARP Head studs
Head Gaskets
Valve cover seals
TB O’ring
10 NGK spark plugs
Valve cover spacers
Timing chain
Not much.
Better than Chrismas
Hey Bud;
If they are in fact sending you 7.600" hardened pushrods, that is very close to stock length and could work with the o.e.m. cylinder heads.
What you need with the Strikers are Hollow, Hardened Pushrods, tapered at each end 7.400" long.
Hopefully you just made a typo.
Hey Bud;
If they are in fact sending you 7.600" hardened pushrods, that is very close to stock length.
I will have to trust John. I measured them and and told him they were 7.600" and he said he will make sure they will send the right ones for the new set up, even if he does keep referring to them as 7.600" They will be checked before they go in too.
Hey Bud;
Good to have someone with the knowlege to jump in for verification . IMG_3889.jpeg
Good, because pushrods that long with your Strikers would cause a MAJOR valvetrain traffic jam.
Unless the low-bleeds are .200" shorter than the o.e.m. lifters; but I doubt it...
Or he is using small base circle cams.
Have checked with John. They are 7.600" for my build. He hasn't used anything shorter before. Maybe because my heads are not shaved or thinner gaskets. My engine man will be double checking everything anyway. He is an absolute perfectionist.
John most likely knows what he's doing
We will have to trust the builder!! As long as he's aware of all the info all will be great! Just don't assume anyone knows what the other knows make sure you know that they know what you know! Get me?
Got you lol
That's all you can do (check everything). He may also being using small base circle cams which would require a longer pushrod (than 7.400)
I hope it works out well for you.
It will be good. When you have these two passionate and excited about the build, then you know you are in good hands. It is not just another motor to them.
John has done lots of these, I have done none. I know who I would trust.
It is good to know you are here Ronnie. Another voice, another angle, keeping me grounded.
I am impatient with engines. I want it fixed now and I will stay up late until it is done. Not what is needed right now
Spent $47100NZ so far. Last customs and GST bill next week then all parts are here.
Just need to pay for balancing, assembly, Torrie retune. Won't be much left out of $55KNZ
Then off to the Dyno
Saw this in Pleasant Point today. Just to take my mind off things. A 1958 Hemi 392. Has 871 blower and Hilborn injection. For a vintage drag boat
