Acceleration and torque problems
You will see a white plastic block on the bracket for the throttle body and kick down cable.
With a small screwdriver, carefully release the white plastic block then slide the outer part of the kickdown cable until the throttle cable AND the kickdown cable will MOVE TOGETHER, then snap the white plastic block back into place to lock that adjustment. I mean, AS SOON AS the throttle is very slightly opened from the idle position, the kickdown needs to move with it.
This adjustment can be quite touchy. If the kickdown cable moves slightly after the throttle cable, your line pressure will be low and cause a sloppy shift at part throttle. If the kickdown cable already has tension on it at idle, it can cause delayed and harsh shifts at light throttle and will need to be relaxed slightly until there is no tension on it.
It may take a few tries, but once it is adjusted properly, all will be wonderful in the 48RE Universe and will be true cause for celebration.
With a small screwdriver, carefully release the white plastic block then slide the outer part of the kickdown cable until the throttle cable AND the kickdown cable MOVE TOGETHER, then snap the white plastic block back into place to lock that adjustment. I mean, AS SOON AS the throttle is very slightly opened from the idle position, the kickdown needs to move with it.
Thank you, I will try it as soon as the weather is fine here and I can take the truck out.
How Ronnie said .. It is touch and might take a few tries
I finaly fixed it. It took me a lot of tries. Now it is shifting smooth. Thank you all for the support. My truck is slowly getting in great shape thanks to you.
PS. Does anyone know how to fix the RPM arrow? It is getting stuck very often. It seem mechanical issue, but its is better to ask you before making wrong moves.
Glad to hear you got that fixed ..
Not sure on the RPM needle maybe someone will chime in that has knowledge on that ..
Thoughts are the gauge has mechanical problems or electrical signal .. can you post a vid to show what it’s doing ?
That's great news!!
Mine has needle problems too. They just love going to the right really quick. Then there is funny smell, not sure what it is. Smells like burning rubber.
I think it’s common with these trucks and built in from the manufacturer ..
