Marc T said:Patrick,
Same thing happened to mine. Couldn't get the pin in!! Put the gears in without the new carrier, shimmed them up and all is good!!! :rock:
So Marc, you used the old carrier?
patrick
mauiSRT/10 said:So Marc, you used the old carrier?
patrick
Marc T said:Yep, stock carrier and all new bearings!!
mauiSRT/10 said:Thanks, I will mention that to the tech as well. I dont remember what you said before, but did you purchase your gears from Unitrax?
patrick
I was told that to use the stock carrier with 4.88's the carrier will have to be spaced over quite a bit to meet the pinion and thats why Unitrax supplies the new carrier in their kit. I have never worked with the 4.88's myself though.Stinker said:So basically Marc T we can install the 4.88's with the stock carrier? This is awesoem news cuz I heard opposite, elaborate brother elaborate!
Stingray said:I was told that to use the stock carrier with 4.88's the carrier will have to be spaced over quite a bit to meet the pinion and thats why Unitrax supplies the new carrier in their kit. I have never worked with the 4.88's myself though.
ROKTMAN said:Glad you got her together Patrick.Bet you can`t wait until the 270 more miles are up ...He he.Good luck with it.:burnout:
