Dean Harvey at Comp Cams selected the cam grind.
He's always made me happy. :rock:
Excellent choice!! Just curious,do you know if Dean designed it or if it was from a previous build?:dontknow:
This is the Procharged truck we just finished Tyler
Great job guys....
Taking your time and doing things carefully always pays off over the long term.
And it's nice to see the Strikers are still being used as a benchmark..
Ronnie
Thanks Ronnie. We didn't have Striker castings to work with, but the old stock castings will surprise you if you know what to do with them. I think the stock Gen 3 castings get a bad rap. A lot of power can be made with them. Also, as you know, there are criteria in addition to air flow numbers on a flow chart that a head should be judged by. Wet flow is one area, which I've spent several decades studying. I'm not saying I know everything about that subject, but I have made big gains modifying the way a head wet flows. You don't see wet flow quality on a flow chart. Only a trained eye can spot it. It's not something the average consumer can quantify unfortunately, so flow numbers still sell heads.
It appears the heads and cam combination are not the limitation on this build. If it had the F2R blower then maybe. I'd like to see a larger set of headers and the cats pulled off on this truck. I think we'd see 1000 rwhp out of it then.
Take care!
Hi Greg,
Liquid fuel doesn't burn and non-homogeneous mixtures burn patterns will show up as clear or actual fuel-washed areas as I am sure you are well aware. It is fascinating stuff for sure..
Ronnie
Sometimes, or actually a lot of the time, a clean area on the intake side of the chamber indicates no fuel, hence no carbon deposit to see. This is where trying to read carbon patterns is tough. A clean area can sometimes (mis)lead the reader to conclude there is fuel jet-washing that part of the chamber when in fact the opposite can be the case.
I still see a lot of power gains from wet flow improvements on FI engines. The important stuff is right at the valve seat, and in the chamber, IMO.
A lot has trickled down to us from Charlotte, but they don't just give it to you of course. It took me many years of looking at that stuff to realize what they were doing to get the fuel mixed up and keep it that way. It is different than drag racing, for sure. That's why most drag racing head porters who have submitted heads (including me) haven't made the cut. Not for lack of power, but for fuel mileage. On the other side of the coin a NASCAR type intake port will not qualify in Pro drag racing. They have to be re-done. Two different animals.
On the heads that are hopelessly too small, such as the Viper heads, I'm able to employ some NASCAR type wet flow techniques to get a little more power out of the finite amount of air/fuel that is getting in. No stone left unturned.
That's just my .02, so salt to taste.
Quick question, do you have the part numbers and pack amounts for the arp bolts for the heads (small bolts I have the stud set) and for the oil pan and valve covers? Or at least if someone knows the length and thread pitch.
Thanks.
not butting in on the conversation, well I guess i ambut my builder jeff collins does alot of the nascar truck series engines, and jsut what you mentioned is what we ran into on our heads, with his experience in both the drag racing ,and now nascar , alot of things has really opened my eyes to the shape and the way heads are designed and ported,
I dont think ours will ever be up to your standard of porting, but we are taking our best shot at it sir
much respect for your work :rock:
The intake manifolds bolts are 1/4-20. So are the valve cover bolts and most of the pan bolts. I *think* a couple of them might be 5/16's, can't remember. I tried to look up the bolt order for John's engine but it's not in the notebook I thought it was in.
ARP 611-1000 is a pack of 5 1/4-20 stainless 12 point bolts with washers. To get a longer bolt just change the last set of numbers. An example would be 611-1250 for the same bolt but 1.250" in length. I get mine online from Summit, they have about the best prices and ship the same day usually.
Hey, I really appreciate tthe kind words, but don't downgrade yourself. I'm just a regular guy that puts his pants on one leg at a time. I know some boastful guys that'll try to make others believe they put their pants on over their heads. Yeah right!![]()
