Any Questions?
Discussion in 'General Discussion' started by rottenronnie, Mar 13, 2023.
Car Parts
  1. Wifey
    Wifey Well-Known Member
    23,588
    667
    May 18, 2006
    The Queen has barely seen sun so maybe the lines will be fine. I'm sure I'll replace them when and if she comes out of hiding - belts and hoses too. She just got a new battery and a new set of shoes are in order. The originals won't cut it :eek::eek::D
    I'll go with the oem lines I'm thinking
    VIPR PWR likes this.
  2. Wifey
    23,588
    667
    May 18, 2006
    Hahaha!!
    my early memories of Brake lines goes back to my first car. 1968 Plymouth valiant 225 slant six. I was out and about and the brakes got squishy so my at the time boyfriend and my current brother in law did the right emergency fix and added motor oil.
    came home that night and told my mechanic Dad about the goings on and OMG!!! I thought the world ended!
    So I learned you Cannot put engine oil in a master cylinder!! I never hated two people worse than the boyfriend and brother in law in my entire life!
    i got to assist in a brake fluid change and bleeding the system out in the dirt yard in the middle of the freaking cold night!
    I was young too back in the 80s!
  3. VIPR PWR
    VIPR PWR Full Access Member
    5,442
    761
    Jun 12, 2007
    FL
    Is there a newer Tuner to replace the SCT ?
    Wifey likes this.
  4. VIPR PWR
    5,442
    761
    Jun 12, 2007
    FL
    Hahaha .. it’s that special 10-w 40 hydronic motor oil enhancement hahaha fails everytime .
    Wifey likes this.
  5. Wifey
    23,588
    667
    May 18, 2006
    Yes it was a huge FAIL. My Dad even said the FFFFFudge word :D
    several times!!
    he said anything would have been better - even water :confused: surprised me he didn't mention beer :rolleyes:
  6. VIPR PWR
    5,442
    761
    Jun 12, 2007
    FL
    I agree water would have been better ,, but dit the oils get you home is the question ,,, with braking ?
    My younger brother worked at a full service gas station years ago , I referred him to my boss hahaha .. he put motor oil in a customers trans ,, luckily it was realized immediately and guess who got to do the trans service hahaha Me ,, the boss and owner of the staion was rather pissed to say the least hahaha
  7. Wifey
    23,588
    667
    May 18, 2006
    hahahaha never send a kid to do a man's job! :p
    oh yes the engine oil worked fine! I just didn't know it wouldn't for very long had the oil been left in there the lines would have swollen up like ball park franks and not worked right from what I could hear in between all the Ffffudge being thrown around :eek:
    I was glad I mentioned it though. I liked my car running top notch. No hoaky crap in my brake system
  8. VIPR PWR
    5,442
    761
    Jun 12, 2007
    FL
    I’ll bet flushing and bleeding was a long process … mistakes happen , ugh !
    Wifey likes this.
  9. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    Our old X3 controllers are no longer supported by SCT.
    Mine is still going, so I've never considered upgrading.
    I'm sure Tuners would have some kind of workaround if your controller ever packed it in.
    Wifey likes this.
  10. VIPR PWR
    5,442
    761
    Jun 12, 2007
    FL
    Ok , just wanted to be sure there wasn’t something new and better out there … My SCT is still operational .. but a bit worried about the tunes again now since Marty is no longer in the picture . Need to get at the least verification that his tune doesn’t have the things you stated . But am going to do that down the road and try to get the other things I want to do caught up on first .. Thanks Ronnie !
    Wifey and rottenronnie like this.
  11. Wifey
    23,588
    667
    May 18, 2006
    I just read about SCT tuners. I didn't know what y'all were talking about. Still don't really but I have a general idea. I know the Queen isn't tuned but is this where you send A part (PCM?) out and get it flashed? If that's it do you get a new one or send the one that came in the truck?
  12. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    In 2005, I sent a brand new ECU away in exchange for another one that had been flashed (tuned). That was bolted onto the firewall exactly where the original used to live because it is still the identical ECU, only now its been reprogrammed. That left me with my original ECU that is resting peacefully in the garage somewhere.
    These days, the handheld SCT Controllers can upload a tune from a Tuner like Chris Jensen or Tory at Unleashed Tuning. These can be sent over the internet as files that are opened with the Liveload software we were talking about, installed on a PC.
    The tune is uploaded to the Controllers via USB from the PC, and the Controller is then plugged into the trucks OBD II Port located on the front lower edge of the dash panel, below the steering column.
    A few minutes later, the ECU is now reprogrammed by the Tuner's tune that came from the SCT Controller.
    Wifey and VIPR PWR like this.
  13. VIPR PWR
    5,442
    761
    Jun 12, 2007
    FL
    You should look into getting a tuner ,,, with the SCT ,, you can reinstall if you want to your stock tune. I believe you get 3 tunes installed from all the tuners . Mine has the factory tune , towing tune and the 93octane I believe for the power tune . I think they sold for $299. When I got mine .
    Wifey likes this.
  14. Wifey
    23,588
    667
    May 18, 2006
    And the original programming stays on the ECU incase it needs set back to factory for whatever reason?
    I'm sure it's easy I'm just trying to grasp it. Sad huh lol
  15. Wifey
    23,588
    667
    May 18, 2006
    Oh, that's what I wondered. That with be a mod right?
  16. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    The original tune stays inside the SCT Programmer, in case you ever wanted to reinstalled it in the ECU, yes.
    You're doing great!!
    Wifey likes this.
  17. Wifey
    23,588
    667
    May 18, 2006
    Great, thanks! Very helpful as usual
  18. VIPR PWR
    5,442
    761
    Jun 12, 2007
    FL
    The tunes give the highest gains on the QCs
    Wifey likes this.
  19. Wifey
    23,588
    667
    May 18, 2006
    I'll probably never do this but in the meantime it's something to learn about. So thanks for all the input!
  20. rottenronnie
    4,020
    1,765
    Jul 4, 2006
    Calgary, Alberta
    Here's more incentive (?) for getting a tune:
    Ask for a Valet Tune in addition to your performance tune (no extra cost) and if you ever have to leave your truck in a repair place or dodgy area, your truck can't be "revved up" or even floored.
    In other words, it would be a low-speed chase if someone stole your truck.
    Just remember not to leave your SCT Controller in the truck. :)
