fastestbrickonearth
what do u typicaly see for numbers on the leak down test and how much can it vary from cylinder to cylinder
K1 quit making rods or steel problem?JTS VENOM PERFORMANCE said:pistons $1500 depending
coating $500 or less
rods if I can find the K1 rods $800 or less
bearings $500 or less
gaskets $450
billet mains $800 or less
honing for mains $1000or less
jsut randon pricing
JTS VENOM PERFORMANCE said:first take it to a very reputible shop, not joes back yard fiasco,
get a leak down test done, and pull some oil and get an oil analysis done,
go from there, those two things will tell you most of what you need to know.
you are jsut going to worry yourself with numbers until then,
jsut plain out figure 10k jsut for the bottom end for a proffessional job, another couple for head job.
but get it checked first, then worry.
an 8 cost less then a thousand and a ten is a lot more then that its called viper tax get use to itfastestbrickonearth said:what makes these motors so hard to build urself other than 10 instead of 8 lol
505'sFastestViper. said:an 8 cost less then a thousand and a ten is a lot more then that its called viper tax get use to it![]()
they have just been a pain to get lately, k1 got in three sets, and I got al three, an they sold before I go them herefastestbrickonearth said:i did 2 cylinders that night i got 20 on one and thirty on another i guess i gotta do them all. is there any chance this could be a lifter or valve seat
nothing, two extra cylinders, two extra rods, bearings, valves, so on , two xtra of everything , plus crank is longer most dont have the dowls to do v-10 cranks and its expensive to buy jsut for one buildfastestbrickonearth said:what makes these motors so hard to build urself other than 10 instead of 8 lol
JTS VENOM PERFORMANCE said:nothing, two extra cylinders, two extra rods, bearings, valves, so on , two xtra of everything , plus crank is longer most dont have the dowls to do v-10 cranks and its expensive to buy jsut for one build
