QuickSilver
Did you disconnect the battery when you installed?
QuickSilver said:Did you disconnect the battery when you installed?
he just didnt get laid last nightQuickSilver said:Did you disconnect the battery when you installed?
JTS VENOM PERFORMANCE said:he just didnt get laid last night
but you should pm cherry and let him see if he can take care of it for you, he worked hard on getting this together for ya'll, not just complain on the forum,
Exo said:Damn I am not to excited to install the one I got from stinker now. Guess I better hope there is a fix before the snow is gone here.
coool morning tangIronhead said:no i did not get laid last night i had to put out this morning before she went to work :aetsch:
i bought it from this forum ,,,thought i could wine about it in this forum also :aetsch:
the ones for the viper are a little different, those they are still working on a fix from what I have been told:dontknow:VIPR PWR said:Others have said to re-flash the computer SCT.
Chub said there was a bad run on some from the viper car site.
Others have adjust the idle screw.
But I think the majority are very satisfied with them.
Contact Cherry preformance or BBK --info on earlier posts...
Da1Chief said:Every one of the TBs that Stinker got was AFTER the sticking/rough idle was noted... They held up sending them to him until after the problem was resolved. I wouldn't worry about the ones he got or sold... As a matter of fact I have one of his myself and it is being installed Mid April along with my Mopar Headers....
Thanks again Stinker... Yooou Beee Daaaa
Mannnn !!!!!! :rock: :rock: :rock: :elefant: :elefant: :elefant:
Try one of these, probably not gonna help with TB thing, but ya won't have to listen to the CD changer go nuts everytime ya disconect the battery.QuickSilver said:Did you disconnect the battery when you installed?
Drive around until it hangs. Once it hangs, dont blip the throttle to get it down. Leave it stuck, pull over and open the head. You'll see a gap between the throttle linkage and the idle set screw. Turn the idle set screw in. just to the point that it touches the linkage. You should be good to go after that.Ironhead said:just installed the BBk ,,,i have to say im not to happy ,,,mine will stick at almost 2000 rpm ,,if i flip the trottle it goes down to normal ,,,,i am thinking of putting my xmetal single blade back on for the price of this thing as i see it right now its not worth it
Ironhead said:i have fixed this problem ,,,and it is not a ecm learning thing as i thought it was the same as the xmetel Tb i have ,,
the pic is a tad blury but right were the blades and shaft meet up there are tiny drag marks on body side and on blades ,,,i took some 2000 grit sand paper and polished it up dabed it with some mobil one and its as smooth as all get out now,,i also loosened the spring cause it was too stiff when i wanted to just feather throttle a tiny bit
Ironhead said:another way is to remove it ,hold it up to a bright light ,,,you should have a tiny bit of light coming out around the blades ,if you have a dark spot with no light going through ,thats were you will drag a bit ,,i had to do this three time to get it were i wanted it ,,,
PM sent JamesIronhead said:dont ask me rookie questions
