ARRESTmeRed04
Exactly what happen to mine...
Ahh, hard to tell in your picture, you have a collapsed lifter
ain't that what i said:dontknow::dontknow::egg:
I don't know I see the clips... how can you tell that one is bad and other is good, the direct the clip is?
So what made you think you had an issue
zero compression in the rear drive cylinder, removed the rocker and it passed leak down and compression. The lifter was stuck up holding the valve open. I had a large amount of air coming out of the passenger valve cover, because the driver hooks to the intake it sucked oil/ metal shavings into the intake.
So lifter got stuck in its bore?
Yes...
Man after reading all these problems with these built motors makes me nervous thinking about doing mine. Hope you guys get it all worked out.
Could you remove it? Wonder if its not a true round lifter casing or something? That or its not getting oiled?![]()
I got it out, it slid right out.
:rock::rock::rock:
fresh lifter & try again???
