mmmmtorque
Awesome pics!!!
Thanks for sharing
Looks like a great upgrade.
Thanks for sharing
RedRamRules said:Very cool Bone, awesome pics
Can you get the same diff. cover for the RC trucks? Thanks.
Chuck B said:Thanks for posting. BTW...I had about the same material on my magnet with my last drain/fill. Previous 2 drain/fills showed normal material attached to the magnet. That large piece you show was/appears to be identical to what I had. I had dodge do a complete axle rebuild (under warranty) as both myself and Viper tech knew something was/is coming apart. Turned out that piece came from an inner wheel bearing outer casing.
Getting the parts for the rebuild was difficult. Dodge had to pull them from the production line in mexico as no new parts were available here state side. I took that to mean its not been a problem with our axles.
1Fast400 said:Would be VERY interesting to see a dyno with the new transmission in it before any other mods are made. I get my tranny from Joe sometime next week. I'll put my suncoast for sale soon. My entire deal was like 7200 bucks. Someone is going to get my tranny for cheap.
NBT said:While he is there have him grab some paint...![]()
I was talking about the differential, what were you inferring, the trans? You are right, I don't think they can go anywhere now.Azmotorhead said:That clip on your rear diff magnet is from the clutch pack in the diff.
That clip keeps all the clutch steels in place. Once the side gears are in place I do not believe the steels can go anywhere. If you go to rebuild the diff clutch packs you'll need new clips
vpr hler said:The reason for this MONSTER TRANNY build is so you are ready for some serious HP work ??
My Ho's loved to be spooned. Especially under the truck.:rock:BOOMER said:he needs the tranny to haul around all of his Ho's he is pimpin![]()
Not to make you feel any worse, but I checked it again today and there was some small shavings again. Probably due to the new magnet.Misterhemi03 said:Your making me feel bad for not changing the fluid in my rear end yet. 16k m
