bwellmaker's build
Are those rotors black?
Amazon
They are EBC 3GD-7277 front and 7278 rear rotors.
Corrected the PN
Of course the black will wear off the pad area but the rest will remain.
That will look bad ass.
B
UIH,
I finally got around to finishing up the Speed Hut Oil temp gauge install. I installed the gauge some time ago but needed to install the new sensor. Pretty straight forward. Access was not bad. I removed the RH front wheel and was able to get the OEM plug off and R&R the sensor. I was able to get my arm between the inter fender liner and the upper A arm.
It was easier access to strip and crimp the terminal lug on the wire from the bottom. The new sensor is grounded through the base so the OEM ground is not used for the new sensor, just the VT/GY wire are used.
I now have oil temp again.
UIH.
B
The busted OEM gauge
[/URL][/IMG]
wiring the new gauge to the A pillar disconect
[/URL][/IMG]
OEM oil temp sensor sensor
[/URL][/IMG]
Base and new sensor
[/URL][/IMG]
Just have to cut off the OEM plug and install terminal lug
[/URL][/IMG]
Lug installed and connected
[/URL][/IMG]
Success
[/URL][/IMG]
UIH,
My 03 DD Ram Hemi needed new floor mats. It has 160K and where my heel rest for the gas pedal, it was about to make a hole through the mat.
That was the perfect reason to buy new LLoyds mats for the SRT-10. Went with the Ultimates with the premium binding Slate Gray.
Simple and sweet.
Nice Matts,
B
[/URL][/IMG]
[/URL][/IMG]
simple is great:rock::rock::rock:
might try a set of these
they are from SRPRacing.com
there are some threads bout them. was a rash of the rubber nubs breakin off a while back
i did the red letterin, they just came "blank".
if they still have that option???
way things been changin lately:mad:
I got brand new OE pedal pads from ROE, cheap too, mats look great B.....These are the one's I got this year from Lloyds for shows:drool:
Thanks guys,
The mats were a real nice addition and it took care of 2 of the many issues I have.
I like the pedals. The SRP has some cool finish options.
Another little addition added was the fuse box cover from JTS.
B
[/URL][/IMG]
That cover looks sweet, Joanne does awesome work.......
Yes she does,
It was tough to decide weather to go with a dipped cover or a painted metal.
The painted cover matched the radiator core cover which was the look I was trying to achieve. I want to do something with the brake reservoir but not sure just what to do. Before I swap out the rubber brake lines I will come up with something.
It looks like a big ass zit on the forehead of life.
B
That's one way to describe it..LOL A billet cap helps some for the brakes.....
UIH,
I picked up a JTS underdrive pulley and belt for a fellow member some time ago. I also snagged a JMB stage 1 traction kit from another fellow member, both at great deals. I could here the stage 2 kit calling my name while I was sleeping so ordered that as well.
I got the chance to install all the cool little goodies today because the boss didn't need his heli to the city.
So here we go.
I pulled the K&N CAI tube for access
[/URL][/IMG]
Took a look at the TB blade screws. They good
[/URL][/IMG]
[/URL][/IMG]
My trusty assistant Cyrano
[/URL][/IMG]
New pulley installed
[/URL][/IMG]
Old shock
[/URL][/IMG]
New shock
[/URL][/IMG]
The slapper Bar bumpers
[/URL][/IMG]
One of the stock bumpers. The stuffing was coming out.
[/URL][/IMG]
It took a a couple hours to install this stuff. All was pretty simple to install. Cyro only slimed me once but about have way through we had to play ball for for a few minuets.
UIH,
Butch
Nice work:D I used some spray paint for plastic,cleaned the reservoir real good and sprayed it where it's at.
Thanks Guys,
A little here a little there. One day soon those new rotors and pads.
Paint the zit, Hummmm there a thought. A good finish is a must. I thought about having it dipped but I have nothing dipped on the truck or engine bay. Some of that stuff is really cool though. Hawk mentioned caps to move attention, that a good idea too. I wish someone made a nice billet one.
Then there is the whole pedal thing now, Dang, I am so confused.
B
I have the cap from BT, beautiful piece, I'll try to find a pic bud.......
