Dom426
More then likely an auto and shifting at 8500 rpm lol
So by stock block you are retaining the pistons rods and crank?
Or ??
Yes sir....until it breaks...we are going to try for 700 rwhp....NA. So I'm at 11.63 now with 510 rwhp....I'm sure I will gain at least .64 seconds with another 190 rwhp(probably more, if I can control it). I'm talking with Greg Good, about porting some striker street heads, bigger valves , flow in the 400 CFM range, a custom designed Solid Roller ( Greg says 30 ftlbs gain over the equal hydraulic roller) along with a custom sheet aluminum intake by Hogan. I will not be turning 8500 rpm however, so if thats what you are really planning on ....then you win, I will most likely be shifting ( and I WILL BE SHIFTING) at 6500 rpm. But I really expect deep into the 10's and still be streetable. Either way we will have a match race....maybe I can catch you sleeping at the line!:rock::burnout:
We are doing a roller cam in the twin turbo with roller bearings it will red line at 9000 rpm!!!!
What do you mean by intake cleanup? What does that consist of?
Yeah get ahold of Rotten Ronnie to get some striker heads and cam and put 100-150shot of NOS and you will have one reliable rocket!!! Good luck with the build, and also some intake clean up wouldn't hurt either!
ah ok. I've read the long thread on here from a few years ago where a guy got his ported out in Cali, didn't net much hp for the cost.
Ronnie, I think Dom is talking about picking up a RC to do a NA build on, not his turbo truck.
Correct it would be another 10 and of course we will call you Ronnie!!
