71dusterjon
does the valve train get oiled through the pushrods?
WOT said:That sounds like exhaust noise. It seems too slow for it to be something hitting a piston (the exhaust stroke only happens every 2 revolutions, so exhaust sounds are usually slow like that). It is either leaking around your PVC breather where it goes into your exhaust or right at the manifold gasket.
Roz-SRT said:A LONG LONG time ago, mine broke the #7 intake spring. . . It sounded pretty identical to the vids you posted. I'd pull the valve covers again.
71dusterjon said:as the this moment, i've found out that the crankcase was under enormous pressure due to the pcv valve wasn't working and instead of sucking the vapors from the crankcase it was putting in boost air. (took oil cap off and vapor was shooting out).
I might be wrong but because the crankcase was under such pressure, it was hard for the starter to turn the motor, although i haven't tried turning the motor since we got it over to my shop.
We did a comp test on all cylinders and here are the numbers:
1-115 2-115
3-110 4-145
5-100 6-145
7-80 8-65
9-45 10-80
I'm waiting till monday to get a leak down tester so i can check to see where i'm actually leaking (valve, rings or head gasket)
I'm still wondering how my motor has took a turn for the worse. before i parked it was running smoothly.
bigike said:How many seconds did you have the starter engaged for? And what the throttle valve open fully.
When i do this there is a black wire with a black connector right by the fuse box it goes to the solenoid. I hook my remote starter to it so you dont have to worry about firing the engine.
Also, was there this sound before? If not we need to not think about dropped valves or spun bearings, haha you can't do either by pulling the exhaust, intake or changing the spark plugs.
I know i sounds like i'm a broken record but you need to isolate the noise and to do that you need to pull the fire off each hole until the noise changes/stops. Then from there you can see if its the plug/wire swapped, or an exhaust leak.
Your last 4 are super low though as stated above.. number 9 is almost dead.
\WOT said:To accurately do a leak down test (and a compression test, as well), you need to put a couple of squirts of oil through the spark plug hole. This will help the rings make a good seal. When the motor is really running, there is a ton of oil splashing around on the bottom of the pistons and the cylinder walls. So, you really need to squirt some oil in there to help it seal. Plus, the rings are made to seal when the motor is warm (the end gaps close up when the motor warms up). So if you can't warm the engine up before you do the leak down test (as it is hell on the spark plug threads in the head), at least do the oil squirt. Best of luck.
