Probably not, Most that would happen is blown seals.71dusterjon said:i was just reading the thread about Bone pulling his motor. is there any way that a rod is bent because the crankcase was preassurized?
FSTJACK said:\
Oil should not be used in a compression or leak down test.
Oil can be used after an initial "DRY" test.
The oil will artificially seal the rings and negate the results of the test if done first.
bigike said:pulling the wires you didn't notice a difference in the knock? If not then it's not in your rotating assembly.
Again if all you did was pull they headers and put the intake on, and change spark plugs you need to work in reverse to find the problem..
Your compression problem has been there for a while.
did you run the stethiscope over the engine?
When you installed the mallary CC evac system did you put it in the right place? before or after the cats..
Also if your CC was pressurized then you would be leaking oil. Are you leaking oil?
Prof said:in my opinion you change plug wires anytime the intake comes off, because it is a bitch to have to do it with the intake on, but has been done.
