Engine light on ?
Famous Brand , Evap leak detection pump for the Dakota -- $100
Standard Brand , Evap leak detection pump for a 10 -- $160
There are others ... These are on Rock Auto .. Ill bet there is no difference in operation and work on any that uses one ..
This could be the culprit also ! Its the most expensive part of the evap system next to the charcoal canaster .
CAN YOU SEE ANY DIFFERENS ? Besides the nipple directions !
You have to drop the gas tank and hope the hose is cracked or the problem ,,,. No dont have to do it either ,, so what if some fumes float out into the air .. been doing that forever ..
So who is going to do it for you hahaha
If you don't need to pass emissions i would leave it lol
View attachment 68459View attachment 68460
I might have left it but the OCD in ME hates seeing an CEL on the dash.
Did you get it fixed? it would be annoying for sure lol
Hahaha ,, we all hate that idiot light ..Sometimes some of us just get use to it hahaha ..
This is a vid and happens to be a Dakota .. havent checked the 10 to see f they are the same ... but this could also be the problem ..
getting access to a scanner and will pull the code and reset it next week. replaced the gas cap already because it kind felt a bit squishy when i fastened it prior to the code popping up.
Nice! Let us know. That would be an easy fix for sure :cool:
To reset the codes just disconnect the battery for a few minutes .. then drve the truck for a it and see if it throws the code again ..if the code is the EVAPORATIVE SYSTEM start and inspect the hose for dry rot or cracked and replace as needed and reset diconnecting the battery again . Other than that a smoke machine put on the evap. System will show the leak .. A hell of a lot cheaper than a dealer or auto shop ..
my codes are gone , i replace a few small inches of vaccum hose . I know I have another cracked hose that connect to the throttle body it may a little ove a ft. Long .. and another at the charcoal canaster under the truck anbot 3 inches of vaccum hose will take car of that ..the code is gone so I believe not a leak ,, YET LOL .
I posted a few vids on making your own cheap but very capable of doing your own smoke check of the system ... personally ill say doing those visual checks and making your own smoke machine would even ne cheaper that buyin a code reader ...
I'd be interested in the DIY smoke machine. can you send me the link for the smoke machine ?
