ZCx - can you share the sizes on the fittings so I don't have to rip mine apart? Any pics? Thanks!
Stinker said:Was thinkin on it, with an external oil cooler available, jsut having a helluva time figuring where to put it
but yeah, should be able to , I got a connection on fittings so hopefully can do them right.
ZX did a hell uva nice job:rock:
Chuck B said:I put mine on passenger side next to the radiator in the opening between the radiator and headlight. Made up some basic brackets for mounting purposes. Idea was that in cold weather I can leave the stock plastic 'diverter', for lack of a better word, thats mounted in the grill/hood in place to keep direct air from flowing over the cooler. In hot weather I simply pull the diverter to get full air steam through the cooler. A series of 1" holes would also work and keep the grill looking somewhat stock.
ONce summer hits here in phx I'll be able to play some more with how well it works then decide if I want to try something else ie add fans.
Stinker said:Thats what I was lookin at:rock: an also behind the a/c cooler, and with the options of a fan for those in the warm areas
ZCx said:lets see if this works. if it does. they are #10 fittins. -10 in AN terms. tried to stay the same I.D. as stock lines.
ZCx said:at block & cooler are o'ring fittins. straight thread.
What year and how may miles? Mine, O6 2000 miles. Should I start to worry? bobbymacZCx said:howdy ya'll,
had an engine oil cooler line bust on me last night. guess i was lucky. looks like it let loose just a bit before i stopped for gas. blew out 4 qts. of oil in a short time. what a friggin mess. had the "normal" seeps is all.
called a wrecker & got back to the shop. dam truck even looked good on the wrecker, roll back wrecker. got the lines off and replaced the hoses with some Strat-o-flex and got her runnin. i can not believe the total yard bird caca setup that dodge put our trucks. i don't know if dodge "up dated" the replacement hoses or not. it looks like they used reg. old heater hose. ordered hose & fittins to do the job correctly as soon as i got back to the house. real purdy red & blue fittins & that fancy stainless steel hose.
so please check or REPLACE ya'll's oil cooler lines.
question? do ya'll guys with all that work & money in the big horse engines use the stock lines??? that would be one hell of a gamble over a 2 bit hose.
ZCx:rock:
Prof said:But if you just want a balls to the wall storming beast that oozes testosterone...you have the right ride.
Prof said:These trucks are wonderful...but yes it costs to play.
There is nothing inexpensive about these monsters. But most of us knew that going in. If the cost of a quart of synthetic oil or a gallon of gas causes you concern, you may not be comfortable with this truck...if six or eight grand turns you stomach to lower your e.t. by half a second, then you may be a little unhappy...if you want to go really quickly....figure $30-$40k...
