Mine is not installed yet, but I ordered the Swivel Seal fittings.
They only come in 0, 45, and 90, so it may not be quite as ideal at the block to frame as the 60 Zcx used, but with these fittings, you don't have the -10 o-ring to -10 flare adapter - the hose end has that o-ring thread on the end and allows swivel to point your hose in the right direction. Earl's part numbers are: 840110 for 0deg, 844510 for 45 deg. With these, no 985010 necessary.
We'll see how well they work in practice, but I think I'll be OK at the block since they start the 45 deg bend closer to the block than a 45 fitting on the end of the 985010 adapter. I'll report back when installed, but it will be a while - travelling.
