FS: Forced Induction SRT10 Partout, OEM parts and Engine parts
Oliver Billet rod set, stock length, stock big end, .927 pin, good for 2000+HP $1000
Diamond Piston set for above rod set 8.8 compression, needs one piston replaced $100
Cloyes Hex adjust timing set $180
Stock Timing set $40
Aeromotive -10AN in/out filter $60
OEM throttle cable $15
OEM brake booster $5
OEM Throttle body complete $60
OEM Throttle body housing and blades $15
OEM Power adjustable pedal set, Auto/gas $10
OEM power adjustable pedal motor $5
OEM oil pickup tube $5
OEM Air bag module $5
OEM rear axle ubolt set $5
OEM coil (4 cyl one) $5
Updated list:
-Suede covered headliner and door sill set, very nice $150
-Single nozzle Nitrous express kit with big carbon solenoids, no bottle or feed line $175
-Roe water injection control box $10
-Big Rotor/High volume/pressure oil pump and front cover assembly PENDING
-Diamond pistons, one bad, 4.040 bore, .927 pin, 8.8 Comp $100
-Stock fuel rails modified with -6 ends on them for a aftermarket fuel system.
Powdercoated reflective chrome, never installed since modified/coated $175
-170 Tstat $20
-Candy red T-stat housing with swap for your stock $30, $130 outright
-Torque limiter setup, worked great even with huge power $75
N20 solenoid set sold
Also have:
SS front brake lines $30
Autometer triple guage pod for center cubby on dash $10
Ill have to measure, they are only long enough for the spring and axle, no drop blocks would fit.
Brake Lines sold
Ive also got a good used billet stock size crank pulley for stock dampners $50, its about .5 # lighter than OEM.
Justin
Updated list:
Powdercoated reflective chrome, never installed since modified/coated $150
-170 Tstat $20
http://farm9.staticflickr.com/8178/8063352651_6bd42aef9b_z.jpg[/IMG
[IMG]http://www.jmbperformance.com/photos/DSC_2820.JPG
