Hi guys,
My truck has a get er down lowering kit, the kit is good as gold and looks nice but I have a bottoming out problem now, is to be expected lowering a vehicle. I've PMed a few people and had some brief discussions but now I'm confused on which way to go exactly. Truck is in the garage ready to be lifted up and worked on but I'm just not sure how to go about leveling my truck out.
It currently sits 1" lower on the RH (your passengers) side. The rear is perfect, around 3-4mm (0.12") higher on the LH side. It bottoms out on anything above 65mph+ and/or with some decent camber roads or dips/bumps, either way it shouldn't be doing it at those speeds. The front has the stock coil spacers + 1 rubber spacer on each side (supplied with kit). I don't really want to put more on one side and have 4 spacers, sounds unsafe to me. I have 4 options and would like serious input in how to tackle the situation safely and they are:
Option #1) - Put 2 extra coil spacers (total = 4) on one side to level it out.
Option #2) - Re-tension leaf springs. Maybe hard to get it 1" exactly + may level out or settle again?
Option #3) - The option I'm leaning to along with option #4. Trim 3/4" to 1" off the LH rear lowering block.
Option #4) - Get a new spring remade, same lb rating but 1" higher.
Pushing the LH rear down in the garage the front RH rises the same amount as being pushed down. This to me makes the most sense using a lower block height and it is safe. No one will see or spot the 3/4" difference in block height if they do they perhaps need to get a life LOL.
The rear is level but at the end of the day one end may have to be slightly off (although not to the naked eye), so the rear it must be. 1" higher in the RH front would be perfectly level so perhaps 3/4" will be level at both ends. With a new 1" higher spring that will push the LH rear down but who knows, maybe not?
Thanks for the help and input in advance. I really, REALLY want to get this sorted out. It's annoying me no end knowing it's off.
I have some bits and pieces to do to the truck that requires jacking it up so I'm waiting until I have a fix for this problem before I tackle everything.
Cheers,
Carl
Cheers,
Carl
