1. GOOD TRIP EQUAL TO ZERO
Ignition on, engine not running.
With the scan tool, read DTCs and record the related Freeze Frame data.
Is the Good Trip Counter displayed and equal to zero?
Yes
Go To 2
No
Refer to the INTERMITTENT CONDTION Diagnostic Procedure.
Perform POWERTRAIN VERIFICATION TEST
2. (K343) ASD RELAY OUTPUT CIRCUIT
2. K343 ASD relay output circuit
Turn the ignition off.
Disconnect the Ignition coil harness connector.
Using a 12-volt test light connected to ground, probe the (K343) ASD Relay Output circuit at the coil harness connector.
With the scan tool, actuate the ASD Relay.
Does the test light illuminate brightly?
Yes
Go To 3
No
Inspect the related fuse. Repair the excessive resistance or short to ground in the (K343) ASD Relay Output circuit.
3. IGNITION COIL RESISTANCE
The resistance of a 8.3L Primary Ignition coil is 0.53 to 0.65 of an ohm.
Measure the resistance of the primary Ignition coil.
Is the resistance within the appropriate specification?
Yes
Go To 4
No
Replace the Ignition coil.
4. IGNITION COIL
Using a 12-volt test light connected to a 12-volt source, probe the Ignition (K18) Igniton Coil No.3 Control circuit.
Crank the engine for 5 seconds while observing the test light.
What is the condition of the test light while cranking the engine?
Brightly blinking.
Replace the Ignition Coil.
ON constantly.
Go To 5
OFF constantly.
Go To 6
5. (K18) COIL CONTROL NO.3 CIRCUIT SHORTED TO GROUND
Disconnect the C1 PCM harness connector.
Measure the resistance between the (K18) Ignition Coil Control No.3 circuit and ground.
Is the resistance below 100 ohms?
Yes
Repair the short to ground in the (K18) Ignition Coil Control No.3 circuit.
No
Go To 7
6. (K18) IGNITION COIL CONTROL NO.3 CIRCUIT OPEN
Measure the resistance of the (K18) Ignition Coil Control No.3 circuit from the Ignition Coil connector to the PCM connector.
Is the resistance below 5.0 ohms?
Yes
Go To 7
No
Repair the open in the (K18) Ignition Coil Control No.3 circuit.
Perform POWERTRAIN VERIFICATION TEST. (Refer to 9 - ENGINE - STANDARD PROCEDURE)
7. PCM
NOTE: Before continuing, check the PCM harness connector terminals for corrosion, damage, or terminal push out. Repair as necessary.
Using the schematics as a guide, inspect the wire harness and connectors. Pay particular attention to all Power and Ground circuits.
If there are no possible causes remaining, view repair.
Repair
Replace and program the Powertrain Control Module per Service Information.
Perform POWERTRAIN VERIFICATION TEST.(Refer to 9 - ENGINE - STANDARD PROCEDURE)
