GutsyGecko
An Amsoil EA026 is a direct replacement for our filters. This new filter brings total oil capacity to exactly 10 quarts. Some stats for this massive filter.
Height (in): 6.982 in.
Outside Diameter (in): 3.663 in.
Relief Valve Open (psi): 8-11 psi
Anti-Drainback Valve: Yes
Smallest Particle Filtered: 98.7% at 20 microns!!!!!!!!
Maximum Burst Pressure (psi): 290 psi
Thread Size: 3/4-16 in.
Gasket Outside Diameter (in): 2.834 in.
Gasket Inside Diameter (in): 2.462 in.
Gasket Thickness (in): 0.200 in.
Cost for this filter is about $20. I currently have one installed, and it works. There is no chatter after start up like some other non-mopar filters. It filters much better than the stock filter, and has nearly double the flow rate and capacity. It still sits a good 1-2 inches above the frame, so it is plenty protected. The extra capacity will help with cooling and filtering. Maybe a vendor wants to start selling these?
