VENOMOUS1 RACING
Honestly don't see why it's not a great source for extra oil capacity and filtration. Very nice IMO. Of course I have 108k on Viper and 090 filters so dunno that I'd change that. :dontknow:
There have been engine failures due to using "OTHER" oil filters. Sometimes it's just noisy, other times they crack, some leak, some reduce oil flow and/or pressure. Use the recommended MOPAR oil filter for best results.
While using oem filters will no doubt give you what you need, cost does play a factor in the use of them. There are other filter that have thicker cases, better media, silicone adbv, and many other features not found on OE filters.
Been running the filter for 12k miles now. Still working great. I realized I should post some decent non-installed pics for size comparison. Here it is!
Could you do that with our engines though?
I'm by far no way knowledgeable in the area of oil life but it would still be the same oil(a little more) circulating through the engine. I guess carrying more oil could last a little longer but not 4x as long as normal.
Its a sincere question
I'm guessing he ment he has done 4 oil changes with these filters?
Maybe, the way I read it though comes off as only running the same filter for 12k. I'm interested because if we could safely extend oil changes to every 12k you would save money and time.
How much did it raise the oil capacity?
I know you said 10 total, but that's what the 06's are from the factory so they would be higher.
