it's ok...
bone stock it was consistently about 1 mpg off...
with the mods, it's a little worse, for some reason:dontknow:
I often miss the point...that goes along with a drooping penis...
I understand lol .
Is there a chance i have a leak in the headers ? And if so is there a way to check ?
I had Bosch and that was not it . So i went to the dealer and got oem and paid like almost 250 for them and still not it .
Use your SCT to clear the codes and go for a drive and see which are still current codes. Regardless, this is the issue for your poor mileage. I can promise that! These are indeed both your front O2 sensors.
When i clear them with the SCT they come back on in like 30 seconds . I tryed setting it back to stock same thing . I put anti foulers on the front same thing , Replaced extensions , o2s , Im lost at this point . We even looked over all the wires and didnt see any spots where the melted . :dontknow:
Definitely pull those anti foulers back out! They won't allow the O2s to read properly being out of the exhaust stream. That is a trick only for rears! I still have to go with something in the wiring?
Ok, there are a cheaper set of O2 sensors available most try to sell you that are universal and you have to splice them into your wiring! Hopefully you bought the plug in ones? The universal ones sucketh! The extensions for the headers you replaced with new as well?
Yes the 02's are plug in i bought them from the dealer oem mopar . The extensions i got from tony . But the one behind the intake we had to trim down because it didnt plug in .
