Went up again today. Review for stage 2 checkride.
I flew a plane I never have been in today. I was told that this thing was a rocket. It is a 2002 172R converted to a SP. So this thing has a higher Hp engine. This thing wanted to fly. Took me by surprise. We did a short field take off. First sign of the more powerful engine was the fact that the brakes wouldn't hold the plane back when I tried to hold it and gun the engine for the short field take off. Then once I got going, this thing shot up. I was applying forward pressure on take off. My trim was set correctly and everything. My instructor was like, don't fight it, let it do its thing. Just watch your speed. Normally where I would be at around 500ft, I was already at 1000ft. It took a bit to get it trimmed out to fly straight. Once I got that we went out west.
First we did another diversion... Figured it all out and headed to Pahokee. Was about a 15 minute trip. I found it but my time was off. If anything with this plane I should have been early. Way early. We cruised at about 140kts. Normally we cruise at about 110kts. Also noticed that this thing was a gas hog (compaired to what I normally fly). We were using 13gal/min when normal is 9gal/min.
Once we flew Pahokee, we then did some hood work. (basically I can't see out the windows, just the gauges). Did fine here. Turn to this, climb to this, decend to this while turning to...
Then he told me to figure out where we were... no problem there either. Told me to head back to the field.
Then Emergency landing practice.. he pulled back my power. First one I was a bit slow. Also didn't go through the engine restart procedure. I was just setting up to land. I would have landed it no problem, but wouldn't I be embarassed if the FAA showed up and the plane would start.
So we did that again. Did much better the second time. Went though all the procedures alot faster. Would have also landed at the spot I picked.
Then back to the field to practice short field landings. This was a bit harder because this fricking plane didn't want to land. I kept coming in high. Did much better on the second one, but still not as short as I liked.
So basically when I do my stage 2 check... I'm not flying in that plane.
