Also thanks to Tony @ JTS for the power steering line solution!!!
JMB Justin said:4. On/Off, it is factory designed as a high/low so it could be used that way if you wanted, but you would have to add your own wiring and low/high thermostat.
As with anything else I sell, if you dont want the harness or whatever, I can come up with a package to suit your needs.
Thanks
Justin
HaroldD said:Hey there Justin - what's the current draw rating on the electric fan you use? I'd like to hookup a progressive controller, but they have their limits.
Also, just so I have a better visual, do the mounting tabs on your shroud attach on the sides of the radiator?
Thanks!
Thanks!
JMB Justin said:Amp draw is about 50 amps on startup, settles down to high 20's when at full speed, this fan is no BS. I checked this with my fluke amp clamp. I had this fan on my 77 charger with a 100amp alternator and no issues, the stock truck charging system is more than capable to handle the large load.
Yes the tabs go directly to the radiator, no factory shroud/fan is retained.
Thanks Justin
yeah i think im gonna be taking my truck over there in the next monthFSTJACK said:This is the same set you put on the red truck.............:elefant::elefant::elefant:
You need to finish getting it on the road/track,:elefant::elefant::elefant: and quit working on it.....:rock::rock::rock:505'sFastestViper. said:yeah i think im gonna be taking my truck over there in the next month
FSTJACK said:You need to finish getting it on the road/track,:elefant::elefant::elefant: and quit working on it.....:rock::rock::rock:
Voodoo said:And this coming from you??? did u not buy a red truck to drive while you worked on the silver one??? HAHAHA![]()
Hows things going Jack???
FSTJACK said:Hey man,
If you can believe it I fly out Wed morning to Justins to tow it to Portland for tuning.
I know I am the worst guy on the forum for letting my builds get completely over the top. I start out with a thermostat and a ported throttle body and end up 100k later............:hello::hello::hello:
Smokey said:it is one of the baddest trucks out there tho jack, you and Justin have great taste![]()
