Just got her home! Couple quick questions...
Discussion in 'General Discussion' started by shirleyjp86, Jun 14, 2021.
Car Parts
  1. shirleyjp86
    shirleyjp86 Active Member
    70
    108
    Jun 11, 2021
    Lavonia GA
    So, I just got my 2005 quad cab home. On the 225 mile journey, I noticed a couple of things -
    1) The coolant temp fluctuated between 195 and 205 and would rise to 210-215 after shutting the engine off.
    2) The transmission stutters a little at low speed / from a dead stop (does okay afterwards.)
    Any ideas? How normal is this?
    Kiwi SRT10, Wifey and AMS3 like this.
  2. AMS3
    AMS3 Well-Known Member
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    My tranny shudders from a dead stop as well, and I just had mine rebuilt last month. As long as I've had my truck (2 yrs) it's shuddered.
    As for temp fluctuation, mine does the same thing. Someone on here with more knowledge might be able to give some insight. 195 - 205 is operating range.
    Kiwi SRT10, Wifey and shirleyjp86 like this.
  3. shirleyjp86
    70
    108
    Jun 11, 2021
    Lavonia GA
    Thank you, man! Makes me feel a little better. I'm hoping to get at least a year or two of fun out this thing before I have to spend any big bucks on 'er! lol
    Kiwi SRT10 and Wifey like this.
  4. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    I replaced the tranny mount, as well, but the shudder is still there. It's possible the motor mounts may be a bit worn from previous owners dogging it. As the the temp, I replaced the thermostat last year for a 170° one. It still reads 195 - 205. I have to get a tune that tells the fan to come on at a lower temp. But, this engine was designed for higher temps from what I've read on here. Hopefully the previous owner didn't drag race with the truck. Cost me $3700 to rebuild the tranny and add a shift kit. The kit shifts hard, throws you into your seat, LOL. But from what others on here, and outside of here, the shift kit actually helps with longevity of the clutches by not allowing them to slip so much. If you find out something else about the shudder, let me know. Hopefully somebody like RottenRonnie on here, can shed some light on this.
    Kiwi SRT10 likes this.
  5. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Hello- Are you referring to the shift at low speeds and light-throttle that can't decide if it wants to be in first or second and jumps back and forth between them?
    VIPR PWR and Wifey like this.
  6. shirleyjp86
    70
    108
    Jun 11, 2021
    Lavonia GA
    Ronnie, I hear you're legendary around these parts. Ya know what? That might actually be what it's doing; "hunting" gears that is. I took it out a few hours ago and it did seem to act better if I gave it more throttle from a dead stop - I'm guessing these engines don't like to lug, nor do these diesel autos?
  7. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Ha!!
    "Legendary" might be a stretch but... thanks! :)
    The 48RE is somewhat of a Dinosaur but I've never really met a perfect automatic nor a perfect anything really.
    The kickdown cable is really sensitive and a SLIGHT loosening of tension on it can reduce/eliminate the 1-2 Watusi.
    My suggestion... Step on it a little harder and go back to whatever it was you were thinking about when it went 1-2, 1-2.
    On the temperature side, these engines DO fluctuate a bit and I wouldn't worry about that either.
    Enjoy your rig!
    VIPR PWR, Kiwi SRT10, AMS3 and 2 others like this.
  8. Wifey
    Wifey Well-Known Member
    23,065
    337
    May 18, 2006
    Taxifornia
    Ronnie is definitely legendary! He's just shy!
    He is like Einstein of the auto world
    Kiwi SRT10, AMS3 and shirleyjp86 like this.
  9. beastmode1
    beastmode1 Full Access Member
    565
    334
    Oct 2, 2014
    Denver, CO
    All SRT vehicles typically run hot my 10's temp also fluctuates to 210 but trust the big cooling radiator fan to tame the heat. That is normal.
    Kiwi SRT10 and AMS3 like this.
  10. beastmode1
    565
    334
    Oct 2, 2014
    Denver, CO
    As for the tranny, I have no idea but mine sometimes does that but shifts normal. Ask Rotten Ronnie he knows more about the 10's internals.
  11. beastmode1
    565
    334
    Oct 2, 2014
    Denver, CO
    Welcome to the RBC.
  12. shirleyjp86
    70
    108
    Jun 11, 2021
    Lavonia GA
    Thank you, Beast. It's good to be here!
  13. John Nock
    John Nock New Member
    2
    3
    Nov 25, 2020
    I bought an05 QC with a shift kit It sucked, T56 swap iii Magic. Pain but doable, I did it and love it ! I now have a very nicely rebuilt “stock” 48RE for sale
  14. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    Hmm, so far it shift's great with the shift kit. Of course I'm not dogging it either... well not that much...ok sometimes.
    Kiwi SRT10 and rottenronnie like this.
  15. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Did you ever get a Tune?
  16. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    No, not yet. Money has been tight lately, so I've been conservative with the cash. Hoping to do it in the next few months. I have a question. What would cause the truck to shudder from a dead stop? It's done it ever since I bought it. I replaced the tranny mount about a month after I bought it, but it didn't help. Could it be the motor mounts? It's not a hard shudder, but I notice it. It smooths out real quick, and it doesn't do it when downshifting or getting on it once she's rolling. Is it just because I'm banging ten cylinders?
  17. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    Please define shudder.
    The engine?
    The transmission?
    You?
    It may not be appropriate to discuss banging on an open public forum.
    Hold that thought, then try this...
    Start your engine.
    Step on the brake.
    Put in Drive.
    With your foot firmly on the brake, slowly press on "the gas" to see if you feel the dreaded shudder.
    If yes, when were the plug wires last replaced?
    If not, go back to the very top request.^^^
  18. AMS3
    1,007
    648
    Aug 8, 2019
    Savannah Ga
    I replaced the plugs and wires last year. It did it since the first time I rode in it before I bought it. I was thinking it was just normal because it's a V-10. I've done the foot on the brake, and it doesn't do it. It's a little vibration when I go from a dead stop and kinda get on it. If I just start out nice and easy, there's no vibration. But like I was saying, it goes away in a second or two as I accelerate. I'm starting to think that maybe the motor mounts may be a tad worn from all the abuse the truck has had over the years.
  19. rottenronnie
    3,895
    1,542
    Jul 4, 2006
    Calgary, Alberta
    There should be a Shudder App for your phone....??
    Sorry AMS3 without being there, it's a bit of a toughie. Doesn't sound serious though.
    It DOES sound like something contacting something else when the engine rocks a bit under a bit of load.
    AMS3 and Kiwi SRT10 like this.
  20. Kiwi SRT10
    Kiwi SRT10 Well-Known Member Supporting Member
    967
    1,000
    Dec 16, 2019
    New Zealand
    Every time I try that I get this funny sensation that something is slipping and a lot of burning smell....like rubber. Then the mirrors won't work it's like it goes all foggy back there.o_O
