Had a great day at the first test and tune of the season. First time out with JTSVenom's new Throttle Body. Second time on the M&H cheater slicks. I knew the air was going to be good, so was hoping for good results. Previous best at Famoso was last Nov.5 , best et 11.818, best speed 116.94, still running the BBK throttle body. Previous best et was 11.736 at Phoenix on Jan.21. Here are my six runs in order:
Run 1: 9am, 54 degrees, DA 249', took it easy 3800 rpm launch, 16.5 psi.
60' 1.757, 1/8th mile 7.620 @ 94.73 mph, 1/4 mile 11.851 @ 116.76 mph.
Run 2: 10am, 59 degrees, DA 606', 4000 rpm, 16.5 psi. Slight bog.
60' 1.596 (new best), 1/8th mile 7.444 @ 92.08 (new best ET 1/8th), 1/4 mile 11.669 @ 117.21 mph (new best ET!!!):rock::rock:
Run 3: 12:30pm, 67 degrees, DA 1214', 4200 rpm, 16.5 psi. No bog, didn't feel spin.
60' 1.668, 1/8th mile 7.527 @ 94.49 mph, 1/4 mile 11.742 @ 117.55 mph.
Run 4: 2 pm, 67 degrees, DA1248', 4200 rpm, 16 psi, again no spin.
60' 1.694, 1/8th mile 7.543 @ 94.75 mph, 1/4 mile 11.758 @ 117.50 mph.
Run 5: 3 pm, 65 degrees, DA 1121', 4000 rpm, 16 psi.
60' 1.689, 1/8th mile 7.490 @ 94.88 mph (new best 1/8th speed), 11.692 @ 118.01 mph (new best speed!!!):rock::rock::burnout:
Run 6: 4:45 pm, 61 degrees, DA 883', 4500 rpm,16 psi.
60' 1.640, 1/8th mile 7.521 @ 94.45 mph, 1/4 mile 11.745 @ 117.29 mph.
Wow 11.669 was better than I expected, Thanks Tony at JTSVenom for a great product. I have to say the everyday driving is a lot smoother with the JTSVenom TB, no fast idle issues what so ever. Truck seems calmer. Big thanks to SRTBrad for a long day.....over four hours of video shot.
I just checked the Nov. 5 results and the DA was 602' , temp was 57 degrees on the 11.818 @ 115.98 run, so comparing the record run yesterday ( 11.669 @ 117.21) is a real test for the JTSVenom TB in that the DA was 606' and the temp 59 degrees, nearly identical conditions. Wow. I couldn't have had a better comparison for testing results. Amazing. Thanks again Tony.
