Cherry Performance
- Joined
- Jan 13, 2009
- Messages
- 379
- Reaction score
- 0
another bump
Venom Power said:WOW, I didn't see this thread before. It's about time for me to change out my X-Metal Gen II. If I take on it could be in black. I can always have it powdercoated a custom color later. Will an Avondale Viper knob screw straight onto these?
Antnee, This is just a replacement steel lever for the B&M not a complete shifter. Great deal if you have a B&M.Venom Power said:WOW, I didn't see this thread before. It's about time for me to change out my X-Metal Gen II. If I take on it could be in black. I can always have it powdercoated a custom color later. Will an Avondale Viper knob screw straight onto these?
FATJACK said:Antnee, This is just a replacement steel lever for the B&M not a complete shifter. Great deal if you have a B&M.
Venom Power said:*rips up sequenced ticket and throws it on the floor* Okay then that about tosses me out the mix. For the time being I'm still an X-Met kind'a guy when it comes to shifters.
FerrariTruck said:those have broken too!And when it does you will be screwed
I do not supply the screws, but I am sure you can buy some stainless screws.Ironhead said:i have a B&M that has never broken ,but i have broken the bolts that bolt this and bottom half shaft,many times ,,,do you supply heavier and or larger ones for the shifter and this handle ..
Ironhead, If you have the aluminum lever from B&M it will break sooner or later, preventative maintenance....If you keep your bolts tight they will not break.Ironhead said:i have a B&M that has never broken ,but i have broken the bolts that bolt this and bottom half shaft,many times ,,,do you supply heavier and or larger ones for the shifter and this handle ..
Hey Ron are the bolt pattern for the X-Metal Gen.10...are they the same as the B&M? I know he bought the top-hat from B&M for his shifter.Cherry Performance said:I do not supply the screws, but I am sure you can buy some stainless screws.
QuickSilver said:Hey Ron are the bolt pattern for the X-Metal Gen.10...are they the same as the B&M? I know he bought the top-hat from B&M for his shifter.
Quick
FATJACK said:Ironhead, If you have the aluminum lever from B&M it will break sooner or later, preventative maintenance....If you keep your bolts tight they will not break.
