Dom426
i run 20 50 and never have less then 50psi 75-100 while drivind
yellowfever#154 said:One other thing, Joe Gibbs oil has a high Zinc content which is a crutial piece of the puzzle for lube when the oil is warm and under load.
Vman455 said:In fact, the ingredient is ZDDP, or zinc dialkyldithiophosphate (say that 5 times fast), and it is the primary anti-wear ingredient in passenger car motor oils. ZDDP doesn't like catalytic converters, however, and the current API classification SM ILSAC GF-4 oils average 800ppm ZDDP (when the Gen I Viper came out in 1992, SG oils averaged 1200ppm). Chrysler switched in 2005 to 0W-40 Mobil 1, which is a European formulation for passenger car diesels (no catalytic converters) and does not meet API SM. It contains 1000ppm ZDDP; Mobil 1 15W-50 contains 1200ppm, if I remember correctly.
A long read:
http://forums.viperclub.org/general...-shells-response-15-40-rotella-viper-tom.html
Hehehehehe whatup teach?Vman455 said:In fact, the ingredient is ZDDP, or zinc dialkyldithiophosphate (say that 5 times fast), and it is the primary anti-wear ingredient in passenger car motor oils. ZDDP doesn't like catalytic converters, however, and the current API classification SM ILSAC GF-4 oils average 800ppm ZDDP (when the Gen I Viper came out in 1992, SG oils averaged 1200ppm). Chrysler switched in 2005 to 0W-40 Mobil 1, which is a European formulation for passenger car diesels (no catalytic converters) and does not meet API SM. It contains 1000ppm ZDDP; Mobil 1 15W-50 contains 1200ppm, if I remember correctly.
A long read:
from what i've read in this thread, should i consider 15w50 over my 0w40 since i drag race my truck?? :dontknow:yellowfever#154 said:http://www.joegibbsracingoil.com/products/hotrod/index.html
Depending on oil temperature gives you the weight you want. Do some reading on this site, there is lots of good information. Currently I am running the BR-30 until the motor is broke in.
moparracing said:from what i've read in this thread, should i consider 15w50 over my 0w40 since i drag race my truck?? :dontknow:
is this where you get your oil?? :Yellow venom said:I'm running 15w50 Gibbs in mine and I drag race it:burnout: :rock: :burnout:,sure wouldn't be a bad idea![]()
JTS VENOM PERFORMANCE said:Hehehehehe whatup teach?
Psycho1122 said:Hey Guys;
I would like to add an alternative to this disscussion.
I FIRMLY believe in Mobil 1 15w50 Syn. I have used it in my sportbikes for over a decade with excellent results. I have concidered it for my RC. However, since it is still under factory warrenty, I did a little research.
http://www.mobil.com/USA-English/MotorOil/Oils/Mobil_1_Turbo_Diesel_Truck_5W-40.aspx
http://www.mobil.com/USA-English/Lubes/PDS/GLXXENPVLMOMobil1_Turbo_Diesel_Truck_5W-40.asp (Note the applications list).
This oil has maintained excellent pressures out here in the Arizona heat w/o parasitic losses from too high of viscosity, has quick flow at start up & has an excellent additive package!
Looks like the best of both worlds.
Has anyone besides "Ramchargerguy" used this?
moparracing said:
Vman455 said:This is just like class--I keep talking and talking, but I don't think anyone's listening!
