pokeytemplar
505'sFastestViper. said:yep mine has the three walboros
So all three pumps run continuously or does each step in as needed to provide the additional fueling requirements?
JMB Justin said:I dont have any pics of it, its all self contained in the stock basket setup.
Justin
Prof said:How about pricing a package that we just have to put in and hook up?
Maybe a special order thing with cash upfront from those who want it...?
Do I hear cash register sounds in your posts???
so what's the stock fuel pump/sytems good for - hp wise ? :dontknow:JMB Justin said:To modify your basket with new pumps, fittings, wiring ran out of the basket, and relays your looking at:
$480 dual pump (1000WHP)
$680 triple pump (1500WHP)
You would need a return style regulator, new fuel line to the rails, and a return line dumping back into the tank. I can get you set up with all of this stuff as well. With these pump setups (or even the stock setup) you should not be racing with a 1/4 tank of gas, the stock tank is long and narrow and the pump assembly is approx. in the middle, so as you're accelerating, the gas is wanting to be at the back of the tank away from the pump(s). I may be able to source some pump assemblies and do it on a core system for those that dont want to have thier truck down for a week.
Justin
JMB Justin said:All three pumps are always on, and all fit in the stock basket. It takes some major mods to the basket to make them fit, some rewiring, etc. They all feed into one line and then split before the rails. Two is adequate for 1000WHP, three would support at least 1500WHP.
Justin
moparracing said:so what's the stock fuel pump/sytems good for - hp wise ? :dontknow:
good info, thanks justin.JMB Justin said:Stock pump is good for high 500's to mid 600's it seems. Roy is out of fuel around 600whp, I have had no signs of running lean at 640whp with a 100% stock fuel system (wet N20 kit).
I havent seen a need to use a fuel pump controller (with the rest of the fuel system being made for that setup), but a deal like the MSD or aeromotive would certainly not be a problem to use.
Justin
