I wasn't going to comment on this anylonger, but today I had to go to a vendor to witness a load test on a tool, and it failed. Got me to thinking, and I think I came up with a way to maybe convey this in terms that non-engineers will under stand.
If you go to your local Home Depot, or Lowes store to look at ladders, you will now find that they are rated for a maximum weight. Generally they start at 200 pounds and then 250, and then 300. You will also see that as the capacity increases, so does the size of the structural members of the ladder, as well as the cost.
I should add that they also include a Safety Factor into their designs. Let's say the safety factor is 10%. That means that the ladder rated at 200 pounds will not fail until it's loaded to 220 pounds. Of course, they don't tell you that, but it's there.
Now let's apply that same engineering practice to our engines. And for this exercise, I'm only going to apply it to the pistons. And I'm only going to use nice round numbers that I'm pulling out of my ass. Don't have the time to do any calculations.
So, we have a nice 10 to 1 compression ratio engine that sees 1000psi at ignition. Let's say that the engineering once again used a safety factor of 10%, so the piston is designed to hold up to 1100psi. Now this is the same as the ladder. If you increase the safety factor, you will increase the weight and cost. And in an engine, you really are trying to minimize the rotating mass.
So then along comes Hot Rod Roy,
we will just refer to him as HRR from now on. HRR isn't satisfied with a fast truck. He wants a faster truck. Well HRR adds a blower, turbo, nitrous, and a Turbonator (or whatever that piece of shit is that they try to sell on late night tv) so he can now go faster. Well with all of HRR's go fast goodies, his cylinder pressures are now in the 1500psi range. Well since the pistons were only designed for 1100psi, there will be a failure. And that is why all the pistons failed. They allowables for the piston design was exceeded in all cylinders. In order for the pistons to have not failed, the engineer would have had to designed for a safety factor of 50%. This would have added considerable cost to the sticker price.
And before someone jumps in and says that they would have gladly paid that price, I have to tell you, you are in the minority. As it was people did not want to pay the existing price of the truck. If they had, dealers would not have had to discount them to move them off of the lot, and they would still be manufacturing them.
Hope that makes sense to some of you.
